elgerg
October 3, 2019, 7:23pm
1
I have a table like:
lv_table_set_cell_value(sensorTable, 1, 0, "Thermostat");
lv_table_set_cell_value(sensorTable, 1, 1, "20.25ºC");
lv_table_set_cell_align(sensorTable, 1, 1, LV_LABEL_ALIGN_RIGHT);
lv_table_set_cell_value(sensorTable, 1, 2, "10");
lv_table_set_cell_align(sensorTable, 1, 2, LV_LABEL_ALIGN_RIGHT);
lv_table_set_cell_value(sensorTable, 1, 3, "-0.20");
When setting the value (via another callback) i would like to set/change the colour.
Ive used the following to set the the text of the cell in my loop:
static char buf[5]; /* max 4 bytes for number plus 1 null terminating byte */
String labelvalue = String(lastmsg_now/1000);
labelvalue.toCharArray(buf, 5);
//row 2 column 3 (0 indexed)
lv_table_set_cell_value(sensorTable, 1, 2, buf);
but i cant figure out how to set the style/colour that cell uses.
Can it be done?
Thanks
Alex
Next time, please use the How-to category and fill out the template.
Have you read the table documentation ?
Essentially, you have 4 cell types to choose from and you can style each one individually. So, as an example, if you made cell (1,2) a type 2 cell, then you could change the type 2 text color.
elgerg
October 4, 2019, 7:41pm
3
Ok will do.
It looks like i overlooked that part of the docs.
Is there any other way of doing the styling? I’m trying to replace the table in my old system with yours, it currently looks like:
As you can see there are 5 rows where i would like to individually change the colour based on the temp.
If there are only 4 cell types I will have to re-think using the table option.
Thanks in advance.
Alex
elgerg
October 4, 2019, 7:57pm
4
Hold off on answering that. I think I’m being dumb…
I need 3 styles, red blue and green, i can then apply one of those to the cell i need…
Thanks again.
elgerg
October 4, 2019, 10:19pm
5
Yes, that was the answer.
To continue this I am using the night theme. As i am changing the colour of the text i have to create a new style.
The one i am copying is lv_style_plain using:
lv_style_copy( &st_temp_blue, &lv_style_plain );
st_temp_blue.text.color = LV_COLOR_BLUE;
But it seems that the background is replaced with the default (white).
Can you tell me how i can get the correct current style for a table?
Ive tried:
const lv_style_t * tbl_style = lv_table_get_style(sensorTable, LV_TABLE_STYLE_CELL1);
lv_style_copy( &st_temp_blue, &tbl_style );
but that errors.
Ive also tried
lv_style_copy( &st_temp_blue, th>style.table );
and
lv_style_copy( &st_temp_blue, th.style.table );
Any help would really be appreciated.
Thanks
Alex
elgerg:
but that errors.
It’s probably because you are taking the address of tbl_style when it’s already a pointer. Try lv_style_copy(&st_temp_blue, tbl_style).
elgerg
October 7, 2019, 7:39pm
7
Damn! You’re right. Thats what happens when you try to play after 1am…
Thank you!
Alex
