How do you add two mask areas together. Right now it seem to only include the overlapping areas of the mask. I need to have two area or-ed together.
Using the following code I’m trying to get two circles to show the text and button underneath the mask area. How can I do this?
I have tried this code in the simulator.
If I change r1 and r2.init
r1.init(a, lv.RADIUS.CIRCLE, False)
r2.init(a, lv.RADIUS.CIRCLE, False)
This will block all of the screen.
to
r1.init(a, lv.RADIUS.CIRCLE, True)
r2.init(a, lv.RADIUS.CIRCLE, True)
This is the reverse of what I want. I can see to red circles on the screen.
I want two transparent circles.
# Initialize
import imp, usys as sys
sys.path.append('https://raw.githubusercontent.com/littlevgl/lv_binding_micropython/release/v7/lib')
import display_driver
import lvgl as lv
# Create a button with a label
lv.scr_act().set_style_local_bg_color(lv.obj.PART.MAIN, lv.STATE.DEFAULT, lv.color_hex3(0xf33))
om = lv.objmask(lv.scr_act(), None)
om.set_size(200, 200)
om.align(None, lv.ALIGN.CENTER, 0, 0)
label = lv.label(om, None)
label.set_long_mode(lv.label.LONG.BREAK)
label.set_align(lv.label.ALIGN.CENTER)
label.set_width(180)
label.set_text("This label will be masked out. See how it works.")
label.align(None, lv.ALIGN.IN_TOP_MID, 0, 20)
cont = lv.cont(om, None)
cont.set_size(180, 100)
cont.set_drag(True)
cont.align(None, lv.ALIGN.IN_BOTTOM_MID, 0, -10)
btn = lv.btn(cont, None)
btn.align(None, lv.ALIGN.CENTER, 0, 0)
btn.set_style_local_value_str(lv.btn.PART.MAIN, lv.STATE.DEFAULT, "Button")
a=lv.area_t()
r1=lv.draw_mask_radius_param_t()
a.x1 = 0
a.y1 = 0
a.x2 = 100
a.y2 = 100
om.add_mask(r1)
a2=lv.area_t()
r2=lv.draw_mask_radius_param_t()
a2.x1 = 100
a2.y1 = 00
a2.x2 = 190
a2.y2 = 100
r2.init(a2, lv.RADIUS.CIRCLE, False)
om.add_mask(r2)```
## Screenshot and/or video
