By default when the dropdown list is closed and the selected items text is too long it obscures the dropdown symbol. This is when the symbol is on the right hand side.
It’s an embedded Linux system using an Atmel SAMA5D31
8.3
I would like to clip the text to where the symbol starts.
I’ve tried using right padding on LV_PART_MAIN, I’ve tried using a symbol with no transparency but then the focus colour gets lost and the symbol stands out. I’ve tried editing the dropdown list code to alter the size of the label’s area in draw_main which achieves what I want but the problem is that the long text is then wrapped onto multiple lines and you can’t read it.
you can modify the example code to reduce the width of the dropdown to see the issue.
##### startup script #####
#!/opt/bin/lv_micropython -i
import lvgl as lv
import display_driver
##### main script #####
# Create a drop down, up, left and right menus
opts = "\n".join([
"Apple",
"Banana",
"Orange",
"Melon",
"Grape",
"Raspberry"])
dd = lv.dropdown(lv.scr_act())
dd.set_options_static(opts)
dd.align(lv.ALIGN.TOP_MID, 0, 10)
dd.set_width(90)
dd.set_dir(lv.DIR.BOTTOM)
dd.set_symbol(lv.SYMBOL.UP)
dd.align(lv.ALIGN.BOTTOM_MID, 0, -10)
dd.set_dir(lv.DIR.RIGHT)
dd.set_symbol(lv.SYMBOL.RIGHT)
dd.align(lv.ALIGN.LEFT_MID, 10, 0)
dd.set_dir(lv.DIR.LEFT)
dd.set_symbol(lv.SYMBOL.LEFT)
dd.align(lv.ALIGN.RIGHT_MID, -10, 0)
Then select Raspberry in the bottom dropdown list.
None.
