How do I set up lv_platformio with lv_port_esp32?
I am trying to create an lvgl application for my ESP32 using platformio. I decided to start by forking lv_platformio and then following the instructions at https://github.com/lvgl/lv_port_esp32#platformio-support
You can find my fork on github at: https://github.com/spierepf/lv_platformio
The result is just an angry watchdog:
␛[0;31mE (70457) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:␛[0m
␛[0;31mE (70457) task_wdt:  - IDLE0 (CPU 0)␛[0m
␛[0;31mE (70457) task_wdt: Tasks currently running:␛[0m
␛[0;31mE (70457) task_wdt: CPU 0: main␛[0m
␛[0;31mE (70457) task_wdt: CPU 1: IDLE1␛[0m
␛[0;31mE (70457) task_wdt: Print CPU 0 (current core) backtrace␛[0m
What am I missing?
In case it is important, I am trying to replicate the first image on the https://github.com/lvgl/lv_port_esp32 page of a common DOIT ESP32 board and a common ILI9488 display
I have that particular ESP32 board and that particular display.
So, I got this working, and I thought that I should share for the next person who comes through facing the same issue:
First, I cloned-and-owned the code from lv_port_esp32:
$ git clone --recurse-submodules https://github.com/lvgl/lv_port_esp32.git
$ cd lv_port_esp32
$ source /home/peter/.platformio/penv/bin/activate
$ pio project init --board esp-wrover-kit
$ rm -rf src
Then, I opened the folder in VS Code, and updated the platform.ini to contain:
[platformio]
src_dir = main
[env:esp-wrover-kit]
platform = espressif32
board = esp-wrover-kit
framework = espidf
In the PlatformIO sidebar menu, I chose Project Tasks/Platform/Run Menuconfig and made the following changes using menuconfig:
Component config
  LVGL configuration
    (320) Maximal horizontal resolution to support by the library.
    (240) Maximal vertical resolution to support by the library.
    [*] Swap the 2 bytes of RGB565 color. Useful if the display has a 8 bit interface (e.g. SPI).
  LVGL TFT Display controller
    Display orientation (Landscape)
    TFT SPI Bus. (VSPI)
    Display Pin Assignments
      (23) GPIO for MOSI (Master Out Slave In)
      [ ] GPIO for MISO (Master In Slave Out)
      (18) GPIO for CLK (SCK / Serial Clock)
      [*] Use CS signal to control the display
      (5)     GPIO for CS (Slave Select)
      [*] Use DC signal to control the display
      (2)     GPIO for DC (Data / Command)
      (4) GPIO for Reset
      [ ] Enable control of the display backlight by using an GPIO.
I then wired the display to my ESP32 according to the pins listed above, and success!
If you have any questions, I am happy to answer them here.
Cheers!
Peter.
Thanks a lot Peter, worked like a charm on M5Stack Core!
Any ideas updating that to lgvl8 while lv_port_esp32 is lagging behind ?
You can use this sample for LVGL 8.x
LovyanGFX (used for display & touch drivers) should auto detect M5Stack Core.
Arduino
ESP-IDF
Ok, got it. The problem is with lvgl_esp_32 drivers, they are not fit for lvgl v8 yet.
Your second link worked directly after changing lovyanggfx defines to M5Stack. Perfect!
(lovyanggfx not popping up in esp-idf’s menuconfig is correct ?)
Thanks for that!
LVGL has a nice architecture and allows any display+touch driver to be integrated.
So in my sample, I used LovyanGFX since it has autodetect as well, which makes it easy to use unlike the manual driver config required for TFT_eSPI.
You can remove
#define LGFX_WT32_SC01
and enable the line for autodetecting M5Stack.
#define LGFX_AUTODETECT
Source Code line here
Yes, Lovyan is not configured using menuconfig. I can create a kconfig file but there are hardly anything to be configured if you use autodetect.
Autodetect, even better! (beforehand I used #define LGFX_M5STACK)
