Please, can someone help me!
I have set up an example to prove my problem in the simulator:
The following code, in place of lv_demo_wideget.c
* @file lv_demo_widgets.c
* INCLUDES
#include "../../lv_demo.h"
#if LV_USE_DEMO_WIDGETS
* DEFINES
* TYPEDEFS
typedef enum {
DISP_SMALL,
DISP_MEDIUM,
DISP_LARGE,
}disp_size_t;
* STATIC PROTOTYPES
static void kb_event_cb(lv_event_t* event);
static void ta_event_cb(lv_event_t* event);
* STATIC VARIABLES
* MACROS
* GLOBAL FUNCTIONS
void lv_demo_widgets(void)
win = lv_win_create(lv_scr_act(), 60);
lv_obj_set_scrollbar_mode(win, LV_SCROLLBAR_MODE_OFF);
/*Add control button to the header*/
navigate_btn = lv_win_add_btn(win, LV_SYMBOL_CLOSE, 60);
lv_win_add_title(win, "Window Home"); /*Set the title*/
mains_btn = lv_win_add_btn(win, LV_SYMBOL_DUMMY "100%", 40);
batt_btn = lv_win_add_btn(win, LV_SYMBOL_BATTERY_FULL, 40);
wifi_btn = lv_win_add_btn(win, LV_SYMBOL_WIFI, 40);
bt_btn = lv_win_add_btn(win, LV_SYMBOL_BLUETOOTH, 40);
//home_open();
cont = lv_win_get_content(win);
lv_obj_set_scrollbar_mode(win, LV_SCROLLBAR_MODE_AUTO);
/*Create a keyboard to use with text areas*/
kb = lv_keyboard_create(lv_scr_act());
lv_obj_add_flag(kb, LV_OBJ_FLAG_HIDDEN);
/*Add my custom event cb to the KB */
lv_obj_add_event_cb(kb, kb_event_cb, LV_EVENT_ALL, NULL);
* Build out TextArea 2
lv_obj_t* textarea_container1 = lv_obj_create(cont);
lv_obj_align(textarea_container1, LV_ALIGN_TOP_MID, 0, 0);
lv_obj_set_size(textarea_container1, LV_HOR_RES - 30, LV_SIZE_CONTENT);
lv_obj_set_flex_flow(textarea_container1, LV_FLEX_FLOW_ROW);
lv_obj_t* ta_label1 = lv_label_create(textarea_container1);
lv_label_set_text(ta_label1, "TextArea 1:");
lv_obj_t* ta_1 = lv_textarea_create(textarea_container1);
lv_textarea_set_text(ta_1, "Some text to Edit");
lv_textarea_set_one_line(ta_1, true);
lv_obj_set_user_data(ta_1, NULL);
lv_obj_add_event_cb(ta_1, ta_event_cb, LV_EVENT_ALL, NULL);
lv_obj_set_flex_grow(ta_1, 1);
lv_obj_t* textarea_container2 = lv_obj_create(cont);
lv_obj_align_to(textarea_container2, textarea_container1, LV_ALIGN_OUT_BOTTOM_LEFT, 0, 0);
lv_obj_set_size(textarea_container2, LV_HOR_RES - 30, LV_SIZE_CONTENT);
lv_obj_set_flex_flow(textarea_container2, LV_FLEX_FLOW_ROW);
lv_obj_t* ta_label2 = lv_label_create(textarea_container2);
lv_label_set_text(ta_label2, "TextArea 2:");
lv_obj_t* ta_2 = lv_textarea_create(textarea_container2);
lv_textarea_set_text(ta_2, "");
lv_textarea_set_one_line(ta_2, true);
lv_textarea_set_password_mode(ta_2, false);
lv_obj_set_user_data(ta_2, NULL);
lv_obj_add_event_cb(ta_2, ta_event_cb, LV_EVENT_ALL, NULL);
lv_obj_set_flex_grow(ta_2, 1);
* Build out TextArea 3
lv_obj_t* textarea_container3 = lv_obj_create(cont);
lv_obj_align_to(textarea_container3, textarea_container2, LV_ALIGN_OUT_BOTTOM_LEFT, 0, 0);
lv_obj_set_size(textarea_container3, LV_HOR_RES - 30, LV_SIZE_CONTENT);
lv_obj_set_flex_flow(textarea_container3, LV_FLEX_FLOW_ROW);
lv_obj_t* ta_label3 = lv_label_create(textarea_container3);
lv_label_set_text(ta_label3, "TextArea 3:");
lv_obj_t* ta_3 = lv_textarea_create(textarea_container3);
lv_textarea_set_text(ta_3, "The keyboard will draw over this...when edited.");
lv_textarea_set_one_line(ta_3, true);
lv_textarea_set_password_mode(ta_3, false);
lv_obj_set_user_data(ta_3, NULL);
lv_obj_add_event_cb(ta_3, ta_event_cb, LV_EVENT_ALL, NULL);
lv_obj_set_flex_grow(ta_3, 1);
* STATIC FUNCTIONS
* @brief kb_event_cb Event callback for Keyboard
lv_obj_t* ta;
//lv_keyboard_def_event_cb(event);
if (code == LV_EVENT_CANCEL)
//TODO AJW lv_obj_set_height(cont, cont_scroll_height);
lv_keyboard_set_textarea(kb, NULL);
if (code == LV_EVENT_READY)
ta = lv_keyboard_get_textarea(kb);
const char* str = lv_textarea_get_text(ta);
/*Normally do something with data here*/
* Restore Cont to original size and delete the KB
lv_obj_set_height(cont, LV_VER_RES);
* @brief ta_event_cb for TextArea that will create a KB with LV_KEYBOARD_MODE_TEXT_LOWER
lv_obj_t* ta = lv_event_get_target(event);
if (code == LV_EVENT_FOCUSED)
lv_keyboard_set_mode(kb, LV_KEYBOARD_MODE_TEXT_LOWER);
lv_keyboard_set_textarea(kb, ta);
lv_obj_clear_flag(kb, LV_OBJ_FLAG_HIDDEN);
lv_obj_update_layout(cont); /*Be sure the sizes are recalculated*/
lv_obj_set_height(cont, LV_VER_RES - lv_obj_get_height(kb) - 60);
lv_obj_scroll_to_view_recursive(ta, LV_ANIM_OFF);
if (code == LV_EVENT_DEFOCUSED)
And the following in the place of lv_demo_widgets.h
* @file lv_demo_widgets.h
#ifndef LV_DEMO_WIDGETS_H
#define LV_DEMO_WIDGETS_H
#ifdef __cplusplus
extern "C" {
* INCLUDES
* DEFINES
* TYPEDEFS
* GLOBAL VARIABLES
* Header Win Buttons
lv_obj_t* navigate_btn;
lv_obj_t* batt_btn;
lv_obj_t* mains_btn;
lv_obj_t* wifi_btn;
lv_obj_t* bt_btn;
* Global vl_win
lv_obj_t* win;
lv_obj_t* cont;
lv_obj_t* kb;
lv_coord_t cont_scroll_height;
* GLOBAL PROTOTYPES
void lv_demo_widgets(void);
* MACROS
#ifdef __cplusplus
} /* extern "C" */
#endif /*LV_DEMO_WIDGETS_H*/
This compiles and illustrates my problem, in spite of doing what the original lv_widget_demo does in a TabView, where the content does scroll up when keyboard pops up.
When you click on the third text area, it will not scroll up …Please help. (I’m sure I’m doing something stupid!)
