SDL stimulator
v8.3
Remove white space around the list widget.
The red line is the border I added for the button, and the gray is the border for the list. I want there to be no white space between the red and gray. In other words, I want the text to be next to the left side of the list.
- Sets the padding of the list.
lv_obj_set_style_pad_hor(list, 0, 0);
- Set the margin of the button.
lv_obj_t *btn = lv_list_add_btn(list, NULL, text_left[i]);
lv_obj_align(btn, LV_ALIGN_RIGHT_MID, 0, 0);
- Listening LV_EVENT_DRAW_PART_BEGIN event
But the list does not have an items component.
void list_draw(lv_obj_draw_part_dsc_t *dsc) {
dsc->rect_dsc->radius = 0;
// dsc->rect_dsc->border_width = 2;
// dsc->rect_dsc->border_color = lv_color_hex(0x39C5BB);
// dsc->rect_dsc->bg_color = lv_color_hex(0x3906);
void list_draw_style_handler(lv_event_t *e) {
lv_obj_t *widget = lv_event_get_target(e);
lv_obj_draw_part_dsc_t *dsc = lv_event_get_param(e);
Style *style = lv_event_get_user_data(e);
if (dsc != NULL && dsc->part == LV_PART_MAIN){
list_draw(dsc);
// if (dsc != NULL && dsc->part == LV_PART_ITEMS){
// printf("ddd\n");
lv_obj_t* add_list() {
lv_obj_t* list;
list = lv_list_create(lv_scr_act());
// Overall style
lv_obj_set_x(list, 30);
lv_obj_set_y(list, 10);
lv_obj_set_width(list, 257);
lv_obj_set_height(list, 195);
// Redraw events and fine-grained style adjustments
lv_obj_add_event_cb(list, list_draw_style_handler, LV_EVENT_DRAW_PART_BEGIN);
return list;
// Dynamically generate list items
void set_list_text(lv_obj_t *widget, char** text_left, char** text_right, int item_num) {
lv_obj_clean(widget);
for (int i = 0; i < item_num; i++)
lv_obj_t *btn = lv_list_add_btn(widget, NULL, text_left[i]);
lv_obj_t *label_left = lv_obj_get_child(btn, 0);
lv_obj_t *label_right = lv_label_create(btn);
// List item style
lv_obj_set_style_pad_top(btn, 0, 0);
lv_obj_set_height(btn, 40);
lv_obj_set_style_pad_left(btn, 0, 0);
lv_obj_set_style_pad_right(btn, 0, 0);
// Text style
lv_obj_align(label_left, LV_ALIGN_LEFT_MID, 0, 0);
lv_obj_align(label_right, LV_ALIGN_RIGHT_MID, 0, 0);
lv_label_set_text(label_left, text_left[i]);
lv_label_set_text(label_right, text_right[i]);
lv_obj_set_user_data(btn, i);
lv_obj_set_style_outline_width(btn, 2, LV_STATE_USER_1);
lv_obj_set_style_outline_color(btn, lv_color_hex(0xff0000), LV_STATE_USER_1);
lv_obj_set_style_outline_pad(btn, 0, LV_STATE_USER_1);
lv_obj_add_state(btn, LV_STATE_USER_1);
