#Description
I am using an existing demo from NXP to try and create a new tab with a single image in the new tab that is in the center of the screen. However, the image is always near the top of the screen just below the tabs.
##MCU/Processor/Board and compiler
I am using the NXP i.MXRT 1050 EVK. Compiler is IAR’s Embedded Workbench for ARM version 8.40.1.
##What to achieve
A single image in the middle of a screen on just a single tab.
##Tried so far
I have tried several things already. They are:
- Using the lv_obj_align(animImg, NULL, LV_ALIGN_CENTER, 0, 0); command.
- Using the lv_obj_align(animImg, NULL, LV_ALIGN_CENTER, 0, 100);
- Creating a transparent canvas and making the canvas the parent of the image
- Making the active screen the parent of the image
- Using the lv_obj_set_x and lv_obj_set_y functions
- Using the lv_obj_set_pos function
- Changing the height and width of the image
None of these have put the image on just the active tab and in the center of the screen (and only one image)
#Code to reproduce
To reproduce this issue you need to first download the NXP software package for the i.MXRT1050 from mcuxpresso.nxp.com. Be sure to select the EVKB-IMXRT1050 and be sure to select littlevgl from the Developer Environment Settings.
Once you have downloaded and extracted the software package (be sure to extract to your hard drive root C:/ as long paths can lead to build errors), open the littlevgl demo located at C:\SDK_2.7.0_EVKB-IMXRT1050\boards\evkbimxrt1050\littlevgl_examples\littlevgl_demo (assuming the SDK was installed to C:).
Then in demo.c, add this function
static void animation_create(lv_obj_t * parent)
static lv_point_t line_points[] = { {(CANVAS_WIDTH/2) -1, (CANVAS_HEIGHT/2)}, {(CANVAS_WIDTH/2) +1, (CANVAS_HEIGHT/2)} };
/*Create new style (thick dark blue)*/
static lv_style_t style_line;
lv_style_copy(&style_line, &lv_style_plain);
style_line.line.color = LV_COLOR_MAKE(0x00, 0x3b, 0x75);
style_line.line.width = 1;
style_line.line.rounded = 1;
style_line.line.opa = LV_OPA_TRANSP;
lv_obj_t * animImg = lv_img_create(parent, NULL);
lv_img_set_src(animImg, &nxp_logo_small);
Replace function demo_create with this:
void demo_create(void)
#if LV_DEMO_WALLPAPER
lv_obj_t * wp = lv_img_create(lv_scr_act(), NULL);
lv_img_set_src(wp, &img_bubble_pattern);
lv_obj_set_width(wp, LV_HOR_RES * 4);
lv_obj_set_protect(wp, LV_PROTECT_POS);
static lv_style_t style_tv_btn_bg;
lv_style_copy(&style_tv_btn_bg, &lv_style_plain);
style_tv_btn_bg.body.main_color = LV_COLOR_HEX(0x487fb7);
style_tv_btn_bg.body.grad_color = LV_COLOR_HEX(0x487fb7);
style_tv_btn_bg.body.padding.ver = 0;
static lv_style_t style_tv_btn_rel;
lv_style_copy(&style_tv_btn_rel, &lv_style_btn_rel);
style_tv_btn_rel.body.empty = 1;
style_tv_btn_rel.body.border.width = 0;
static lv_style_t style_tv_btn_pr;
lv_style_copy(&style_tv_btn_pr, &lv_style_btn_pr);
style_tv_btn_pr.body.radius = 0;
style_tv_btn_pr.body.opa = LV_OPA_50;
style_tv_btn_pr.body.main_color = LV_COLOR_WHITE;
style_tv_btn_pr.body.grad_color = LV_COLOR_WHITE;
style_tv_btn_pr.body.border.width = 0;
style_tv_btn_pr.text.color = LV_COLOR_GRAY;
lv_obj_t * tv = lv_tabview_create(lv_scr_act(), NULL);
lv_obj_set_parent(wp, ((lv_tabview_ext_t *) tv->ext_attr)->content);
lv_obj_set_pos(wp, 0, -5);
lv_obj_t * tab1 = lv_tabview_add_tab(tv, "Write");
lv_obj_t * tab2 = lv_tabview_add_tab(tv, "List");
lv_obj_t * tab3 = lv_tabview_add_tab(tv, "Chart");
lv_obj_t * tab4 = lv_tabview_add_tab(tv, "Anim");
#if LV_DEMO_WALLPAPER == 0
/Blue bg instead of wallpaper/
lv_tabview_set_style(tv, LV_TABVIEW_STYLE_BG, &style_tv_btn_bg);
lv_tabview_set_style(tv, LV_TABVIEW_STYLE_BTN_BG, &style_tv_btn_bg);
lv_tabview_set_style(tv, LV_TABVIEW_STYLE_INDIC, &lv_style_plain);
lv_tabview_set_style(tv, LV_TABVIEW_STYLE_BTN_REL, &style_tv_btn_rel);
lv_tabview_set_style(tv, LV_TABVIEW_STYLE_BTN_PR, &style_tv_btn_pr);
lv_tabview_set_style(tv, LV_TABVIEW_STYLE_BTN_TGL_REL, &style_tv_btn_rel);
lv_tabview_set_style(tv, LV_TABVIEW_STYLE_BTN_TGL_PR, &style_tv_btn_pr);
write_create(tab1);
list_create(tab2);
chart_create(tab3);
animation_create(tab4);
#if LV_DEMO_SLIDE_SHOW
lv_task_create(tab_switcher, 3000, LV_TASK_PRIO_MID, tv);
Add the prototype:
static void animation_create(lv_obj_t * parent);
And add the defines
#define CANVAS_WIDTH 206
#define CANVAS_HEIGHT 100
I may have missed something but that should be everything.
Thanks,
Chris
