Simulation with the help of ZephyrProject.
8.3
There are buttons (up & down) and with them I want to navigate through a table and also highlight the “active” row.
The example is a good starting point.
I can create a table, fill in some rows, the alternating background (white, grey) works.
Then I reduced the table to a single column and extended the example with
if(row == row_highlighted)
dsc->rect_dsc->bg_color = lv_color_mix(lv_palette_main(LV_PALETTE_BLUE), dsc->rect_dsc->bg_color, LV_OPA_10);
dsc->rect_dsc->bg_opa = LV_OPA_COVER;
Now the first row gets a blue background. But the draw_event_cb() is just for the initial drawing (right?), so I needed another event. I chose change_event_cb()
static void change_event_cb(lv_event_t * e)
// if the cells are drawn...
if(dsc != NULL) //MUST, otherwise crash
if(dsc->part == LV_PART_ITEMS)
uint32_t row = dsc->id / lv_table_get_col_cnt(obj);
uint32_t col = dsc->id - row * lv_table_get_col_cnt(obj);
// make every 2nd row grayish
if((row != 0 && row % 2) == 0)
dsc->rect_dsc->bg_color = lv_color_mix(lv_palette_main(LV_PALETTE_GREY), dsc->rect_dsc->bg_color, LV_OPA_10);
In general it’s working. But I have to click on a button first and then also on the table. The final application doesn’t have a touch screen, so I need to trigger this “table was clicked”-event by hand.
How do I do that?
