I use style on imgbtn and set a style similar to btn, but when I touch the imgbtn, there is no change. I also tried to set the imgbtn style in the official document, and there is no change.I want to set the transition effect of imgbtn to be similar to these effect setting functions of img
static lv_style_t style;
lv_style_init(&style);
/*Set a background color and a radius*/
lv_style_set_radius(&style, LV_STATE_DEFAULT, 5);
lv_style_set_bg_opa(&style, LV_STATE_DEFAULT, LV_OPA_COVER);
lv_style_set_bg_color(&style, LV_STATE_DEFAULT, LV_COLOR_SILVER);
/*Set different background color in pressed state*/
lv_style_set_bg_color(&style, LV_STATE_PRESSED, LV_COLOR_GRAY);
/*Set different transition time in default and pressed state
*fast press, slower revert to default*/
lv_style_set_transition_time(&style, LV_STATE_DEFAULT, 500);
lv_style_set_transition_time(&style, LV_STATE_PRESSED, 200);
/*Small delay to make transition more visible*/
lv_style_set_transition_delay(&style, LV_STATE_DEFAULT, 100);
/*Add `bg_color` to transitioned properties*/
lv_style_set_transition_prop_1(&style, LV_STATE_DEFAULT, LV_STYLE_BG_COLOR);
Arm
v7
Implement img-like transition methods on imgbtn
Refer to the official document to set the stytle
// style
lv_style_init(&style_imgbtn);
lv_style_set_image_recolor_opa(&style_imgbtn, LV_STATE_PRESSED, LV_OPA_1);
lv_style_set_image_recolor(&style_imgbtn, LV_STATE_PRESSED, GUI_APP_SILVER);
x_pos = 40 + (i * 60);
y_pos = 36;
lv_obj_t * imgbtn = lv_imgbtn_create(img_bg, NULL);
lv_imgbtn_set_src(imgbtn, LV_BTN_STATE_PRESSED, item[i].icon_img);
lv_imgbtn_set_src(imgbtn, LV_BTN_STATE_RELEASED, item[i].icon_img);
lv_obj_set_pos(imgbtn, x_pos, y_pos);
lv_obj_set_size(imgbtn, 30, 30);
lv_obj_add_style(imgbtn, LV_LABEL_PART_MAIN, &style_imgbtn);
