How can I align the bottom of two text lables
I’m on v9.0
I’m trying to make two text labels with different font sizes align as if they were written on the same horizontal line. The code I’ve tried is
int align_content_bottom(lv_obj_t *reference, lv_obj_t *alignee) {
    syslog(LOG_ERR, "aligning");
    lv_area_t refarea;
    lv_area_t algnarea;
    lv_obj_update_layout(alignee);
    lv_obj_get_content_coords(reference, &refarea);
    lv_obj_get_content_coords(alignee, &algnarea);
    lv_obj_set_y(alignee, lv_obj_get_y(alignee) - (algnarea.y2 - refarea.y2));
    return 0;
Although the content bottoms are listed as the same, the alignee is always below the reference, regardless of which uses the bigger font. I may be misunderstanding the content area, but how can I find the true bottom of the text which is drawn?
Hey,
You can calculate is the required offset like this:
    lv_obj_t * label1 = lv_label_create(lv_screen_active());
    lv_label_set_text(label1, "Asyb.");
    lv_obj_set_style_text_font(label1, &lv_font_montserrat_40, 0);
    lv_obj_t * label2 = lv_label_create(lv_screen_active());
    lv_label_set_text(label2, "It is a text. ");
    lv_obj_set_style_text_font(label2, &lv_font_montserrat_16, 0);
    lv_obj_set_x(label2, 150);
    int32_t y = lv_font_montserrat_40.line_height - lv_font_montserrat_40.base_line;
    y -= lv_font_montserrat_16.line_height - lv_font_montserrat_16.base_line;
    lv_obj_set_style_translate_y(label2, y, 0);
Going back to this problem after a while I made a function which aligns the baseline of one object to the baseline of another based on the above reply:
int align_text_base_line_to(lv_obj_t *obj, lv_obj_t *base) {
    const lv_font_t *obj_font = lv_obj_get_style_text_font(obj, LV_PART_MAIN);
    const lv_font_t *base_font = lv_obj_get_style_text_font(base, LV_PART_MAIN);
    if (!obj_font || !base_font)
        return -1;
    int y = base_font->line_height - base_font->base_line;
    y -= obj_font->line_height - obj_font->base_line;
    lv_obj_set_y(obj, lv_obj_get_y(base) + y);
    return 0;
Thank you for your help. Hope this cuts a corner off the next person trying to do this.
