I am facing quite strange performance hit from … animations? It is quite hard for me to track where it comes from because of unexpected results when I try to isolate the slowdown cause.
So I am designing UI which will display data from two identical power management systems. Basically my screen is divided in half and on both sides (I will call them panels) I have the same content. I have designed some animations which would help to understand the power flow.
I uploaded the video for reference.
The problem is that when I have most “advanced” version of animations on both panels the CPU usage jumps to 100% and frames drop from 33 to 21-24. (0:00-0:08 on video) At first I assumed: ok, the animations are simply too “expensive” so I will get rid of them. But later I realized that when I have “advanced” animation on one panel and static screen on the other one then cpu usage is around 0-4%. It confused me a little. I started to experiment a little and found out that disabling the animation which makes the “shadow” of the power source glow (it is blue one on the beginning of the video) also reduces cpu usage to 12-20% with both panels in “most advanced” configuration. So I assumed that this animation is the reason of the slowdown. But having this “glowing” animation isolated on both sides of the screen (like on right side in 0:08-0:19) gives me literally 0% cpu usage. At the end of the video I have another configuration in which I have 2x “glowing shadow” animation and 2x " 6 moving points" animations and in this configuration I got round 20% cpu usage (although it is the very similar configuration to the one at the beginning).
I am wondering if this has something to do with how the display is being refreshed?
I am using Raspberry Pi Zero 2 with framebuffer display driver, my display is 1024x600 px.
Below I attached code for animations:
def anim_shadow_opa(obj, val):
obj.set_style_shadow_opa(val,0)
obj.invalidate()
def shadow_pulse_animation(obj,level):
a = lv.anim_t()
a.init()
a.set_var(obj)
a.set_values(level, 255)
a.set_time(1500)
a.set_playback_time(1500)
a.set_repeat_count(lv.ANIM_REPEAT.INFINITE)
a.set_path_cb(lv.anim_t.path_ease_in_out)
a.set_custom_exec_cb(lambda a,val: anim_shadow_opa(obj,val))
anim = a.start()
return anim
def anim_x_y_predefined_path(obj,val,path,color1,color2):
obj.set_pos(path[val][0],path[val][1])
color_ratio = round((val/len(path))*255)
obj.set_color(color2.color_mix(color1,color_ratio))
def one_to_two_animation(l11,l12,l13,l21,l22,l23,source_color,dest_color_upper,dest_color_lower,starting_point):
path_lower_abs = [(0, 0), (1, 0), (2, 0), (3, 0), (4, 0), (5, 0), (6, 0), (7, 0), (8, 0), (9, 0), (10, 0), (11, 0), (12, 0), (13, 0), (14, 0), (15, 0), (16, 0), (17, 0), (18, 0), (19, 0), (20, 0), (21, 0), (22, 0), (23, 0), (24, 0), (25, 0), (26, 0), (27, 0), (28, 0), (29, 0), (30, 0), (31, 0), (32, 0), (33, 0), (34, 0), (35, 0), (36, 0), (37, 0), (38, 0), (39, 0), (40, 0), (41, 0), (42, 0), (43, 0), (44, 0), (45, 0), (46, 0), (47, 0), (48, 0), (49, 0), (50, 0), (51, 0), (52, 0), (53, 0), (54, 0), (55, 0), (56, 0), (57, 0), (58, 0), (59, 0), (60, 0), (61, 0), (62, 0), (63, 0), (64, 0), (65, 0), (66, 0), (67, 0), (68, 0), (69, 0), (70, 0), (71, 0), (72, 0), (73, 0), (74, 0), (75, 0), (76, 0), (77, 0), (78, 0), (79, 0), (80, 0), (81, 0), (82, 0), (83, 0), (84, 0), (85, 0), (86, 0), (87, 0), (88, 0), (89, 0), (90, 0), (91, 0), (92, 0), (93, 0), (94, 0), (95, 0), (96, 0), (97, 0), (98, 0), (99, 0), (100, 0), (101, 1), (102, 1), (103, 1), (104, 2), (105, 3), (106, 3), (107, 4), (108, 5), (109, 6), (109, 7), (110, 8), (111, 9), (111, 10), (111, 11), (112, 12), (112, 13), (112, 14), (112, 15), (112, 14), (112, 15), (112, 16), (112, 17), (112, 18), (112, 19), (112, 20), (112, 21), (112, 22), (112, 23), (112, 24), (112, 25), (112, 26), (112, 27), (112, 28), (112, 29), (112, 30), (112, 31), (112, 32), (112, 33), (112, 34), (112, 35), (112, 36), (112, 37), (112, 38), (112, 39), (112, 40), (112, 41), (112, 42), (112, 43), (112, 44), (112, 45), (112, 46), (112, 47), (112, 48), (112, 49), (112, 50), (113, 51), (113, 52), (113, 53), (114, 54), (115, 55), (115, 56), (116, 57), (117, 58), (118, 59), (119, 59), (120, 60), (121, 61), (122, 61), (123, 61), (124, 62), (125, 62), (126, 62), (127, 62), (128, 62), (129, 62), (130, 62), (131, 62), (132, 62), (133, 62), (134, 62), (135, 62), (136, 62), (137, 62), (138, 62), (139, 62), (140, 62), (141, 62), (142, 62), (143, 62), (144, 62), (145, 62), (146, 62), (147, 62), (148, 62), (149, 62), (150, 62), (151, 62), (152, 62), (153, 62), (154, 62), (155, 62), (156, 62), (157, 62), (158, 62), (159, 62), (160, 62), (161, 62), (162, 62), (163, 62), (164, 62), (165, 62), (166, 62), (167, 62), (168, 62), (169, 62), (170, 62), (171, 62), (172, 62), (173, 62), (174, 62), (175, 62), (176, 62), (177, 62), (178, 62), (179, 62), (180, 62), (181, 62), (182, 62), (183, 62), (184, 62), (185, 62), (186, 62), (187, 62), (188, 62), (189, 62), (190, 62), (191, 62), (192, 62), (193, 62), (194, 62), (195, 62), (196, 62), (197, 62), (198, 62), (199, 62), (200, 62), (201, 62), (202, 62), (203, 62), (204, 62), (205, 62), (206, 62), (207, 62)]
path_upper_abs = [(0, 0), (1, 0), (2, 0), (3, 0), (4, 0), (5, 0), (6, 0), (7, 0), (8, 0), (9, 0), (10, 0), (11, 0), (12, 0), (13, 0), (14, 0), (15, 0), (16, 0), (17, 0), (18, 0), (19, 0), (20, 0), (21, 0), (22, 0), (23, 0), (24, 0), (25, 0), (26, 0), (27, 0), (28, 0), (29, 0), (30, 0), (31, 0), (32, 0), (33, 0), (34, 0), (35, 0), (36, 0), (37, 0), (38, 0), (39, 0), (40, 0), (41, 0), (42, 0), (43, 0), (44, 0), (45, 0), (46, 0), (47, 0), (48, 0), (49, 0), (50, 0), (51, 0), (52, 0), (53, 0), (54, 0), (55, 0), (56, 0), (57, 0), (58, 0), (59, 0), (60, 0), (61, 0), (62, 0), (63, 0), (64, 0), (65, 0), (66, 0), (67, 0), (68, 0), (69, 0), (70, 0), (71, 0), (72, 0), (73, 0), (74, 0), (75, 0), (76, 0), (77, 0), (78, 0), (79, 0), (80, 0), (81, 0), (82, 0), (83, 0), (84, 0), (85, 0), (86, 0), (87, 0), (88, 0), (89, 0), (90, 0), (91, 0), (92, 0), (93, 0), (94, 0), (95, 0), (96, 0), (97, 0), (98, 0), (99, 0), (100, 0), (101, -1), (102, -1), (103, -1), (104, -2), (105, -3), (106, -3), (107, -4), (108, -5), (109, -6), (109, -7), (110, -8), (111, -9), (111, -10), (111, -11), (112, -12), (112, -13), (112, -14), (112, -15), (112, -14), (112, -15), (112, -16), (112, -17), (112, -18), (112, -19), (112, -20), (112, -21), (112, -22), (112, -23), (112, -24), (112, -25), (112, -26), (112, -27), (112, -28), (112, -29), (112, -30), (112, -31), (112, -32), (112, -33), (112, -34), (112, -35), (112, -36), (112, -37), (112, -38), (112, -39), (112, -40), (112, -41), (112, -42), (112, -43), (112, -44), (112, -45), (112, -46), (112, -47), (112, -48), (112, -49), (112, -50), (113, -51), (113, -52), (113, -53), (114, -54), (115, -55), (115, -56), (116, -57), (117, -58), (118, -59), (119, -59), (120, -60), (121, -61), (122, -61), (123, -61), (124, -62), (125, -62), (126, -62), (127, -62), (128, -62), (129, -62), (130, -62), (131, -62), (132, -62), (133, -62), (134, -62), (135, -62), (136, -62), (137, -62), (138, -62), (139, -62), (140, -62), (141, -62), (142, -62), (143, -62), (144, -62), (145, -62), (146, -62), (147, -62), (148, -62), (149, -62), (150, -62), (151, -62), (152, -62), (153, -62), (154, -62), (155, -62), (156, -62), (157, -62), (158, -62), (159, -62), (160, -62), (161, -62), (162, -62), (163, -62), (164, -62), (165, -62), (166, -62), (167, -62), (168, -62), (169, -62), (170, -62), (171, -62), (172, -62), (173, -62), (174, -62), (175, -62), (176, -62), (177, -62), (178, -62), (179, -62), (180, -62), (181, -62), (182, -62), (183, -62), (184, -62), (185, -62), (186, -62), (187, -62), (188, -62), (189, -62), (190, -62), (191, -62), (192, -62), (193, -62), (194, -62), (195, -62), (196, -62), (197, -62), (198, -62), (199, -62), (200, -62), (201, -62), (202, -62), (203, -62), (204, -62), (205, -62), (206, -62), (207, -62)]
path_upper = [(x[0]+starting_point[0],x[1]+starting_point[1]) for x in path_upper_abs]
path_lower = [(x[0]+starting_point[0],x[1]+starting_point[1]) for x in path_lower_abs]
interval = 6000
steps = len(path_lower)
a11 = lv.anim_t()
a11.init()
a11.set_var(l11)
a11.set_values(0, steps-1)
a11.set_delay(0)
a11.set_time(3*interval)
a11.set_repeat_count(lv.ANIM_REPEAT.INFINITE)
a11.set_path_cb(lv.anim_t.path_ease_in_out)
a11.set_custom_exec_cb(lambda a,val: anim_x_y_predefined_path(l11,val,path_upper,source_color,dest_color_upper))
anim11 = a11.start()
a12 = lv.anim_t()
a12.init()
a12.set_var(l12)
a12.set_values(0, steps-1)
a12.set_delay(1*interval)
a12.set_time(3*interval)
a12.set_repeat_count(lv.ANIM_REPEAT.INFINITE)
a12.set_path_cb(lv.anim_t.path_ease_in_out)
a12.set_custom_exec_cb(lambda a,val: anim_x_y_predefined_path(l12,val,path_upper,source_color,dest_color_upper))
anim12 = a12.start()
a13 = lv.anim_t()
a13.init()
a13.set_var(l13)
a13.set_values(0, steps-1)
a13.set_delay(2*interval)
a13.set_time(3*interval)
a13.set_repeat_count(lv.ANIM_REPEAT.INFINITE)
a13.set_path_cb(lv.anim_t.path_ease_in_out)
a13.set_custom_exec_cb(lambda a,val: anim_x_y_predefined_path(l13,val,path_upper,source_color,dest_color_upper))
anim13 = a13.start()
a21 = lv.anim_t()
a21.init()
a21.set_var(l21)
a21.set_values(0, steps-1)
a21.set_delay(int(0.5*interval))
a21.set_time(3*interval)
a21.set_repeat_count(lv.ANIM_REPEAT.INFINITE)
a21.set_path_cb(lv.anim_t.path_ease_in_out)
a21.set_custom_exec_cb(lambda a,val: anim_x_y_predefined_path(l21,val,path_lower,source_color,dest_color_lower))
anim21 = a21.start()
a22 = lv.anim_t()
a22.init()
a22.set_var(l22)
a22.set_values(0, steps-1)
a22.set_delay(int(1.5*interval))
a22.set_time(3*interval)
a22.set_repeat_count(lv.ANIM_REPEAT.INFINITE)
a22.set_path_cb(lv.anim_t.path_ease_in_out)
a22.set_custom_exec_cb(lambda a,val: anim_x_y_predefined_path(l22,val,path_lower,source_color,dest_color_lower))
anim22 = a22.start()
a23 = lv.anim_t()
a23.init()
a23.set_var(l23)
a23.set_values(0, steps-1)
a23.set_delay(int(2.5*interval))
a23.set_time(3*interval)
a23.set_repeat_count(lv.ANIM_REPEAT.INFINITE)
a23.set_path_cb(lv.anim_t.path_ease_in_out)
a23.set_custom_exec_cb(lambda a,val: anim_x_y_predefined_path(l23,val,path_lower,source_color,dest_color_lower))
anim23 = a23.start()
return [anim11, anim12, anim13, anim21, anim22, anim23]
The “moving points” animations work in the way that 6 lv_led’s are moved along predefined path and have their color changed gradually.
Maybe there is a better way to make this animations? Maybe there are some adjustments I should do in my framebuffer driver? I was expecting that with such cpu (Broadcom BCM2710A1 1GHz) I won’t have problems Every advice much appreciated!
