Reduce CPU usage of music_demo on the Toradex Verdin AM62 target board. On my Linux PC the same app uses ~5–6% CPU, but on the AM62 target it uses ~99–100% CPU.
Built and ran the app on both platforms using the same LVGL demo. Compared CPU usage between the two. Haven’t yet changed any LVGL rendering/buffer configuration or SDL driver settings.
/* Using the standard music_demo from LVGL demos, unmodified */
- MCU/MPU/Board: oradex Verdin AM62
- LVGL version: Latest(master) Latest
Build commands (on Verdin AM62 toolchain):
source /opt/tdx-xwayland/7.6.1/environment-setup-aarch64-tdx-linux
cmake -DCMAKE_TOOLCHAIN_FILE=$OECORE_NATIVE_SYSROOT/usr/share/cmake/OEToolchainConfig.cmake -DCMAKE_BUILD_TYPE=Release ..
make -j$(nproc)
Run command (on target):
XDG_RUNTIME_DIR=/run/user/0 WAYLAND_DISPLAY=wayland-1 SDL_VIDEODRIVER=wayland LIBGL_ALWAYS_SOFTWARE=1 ./music_demo
