Help with styles and themes
Hi there, I am struggling with getting themes and styles to work properly.
I have created two themes, a “light” theme and a “dark” theme. The dark theme is a theme on its own, as I want to specify the behaviour of the dark theme myself - so it isn’t built as a standard lvgl “dark” theme.
My themes seem to be applying, to an extent. Some of the objects are getting the new styles, but others aren’t. Also, the styles are only applied if I specify the theme at compile time (hardcoded), but when I try to toggle between them ,the themes aren’t applied to existing objects.
I am also not sure I am creating the themes correctly, I understand that they behave as a collection of styles, but from what I see in the documentation and examples, the styles aren’t applied automatically, and they aren’t really part of the theme, if that makes sense, it is up to the user to implement and apply the styles in the lv_theme_set_apply_cb. Please correct me if I am wrong here.
A custom board, with an STM32F769BIT6. I am using STM32CubeIDE
Version 8.1+ (master, latest)
I want to be able to specify theme styles for two custom themes, I want to switch between them at runtime and have the styles apply to all objects.
I have the themes created, I have specified a few styles and have set the theme callbacks. I am having trouble applying the themes to all objects.
For instance, I have normal buttons, which seem to get the styles when they are created (if the theme is specified at compile time), but buttons which are part of a list don’t get the styles applied to them.
Code
This is where I create my themes.
 *Local variables
static void Display_DarkThemeApply(lv_theme_t * darkTheme, lv_obj_t * obj);
static void Display_LightThemeApply(lv_theme_t * darkTheme, lv_obj_t * obj);
 * This function initialises the dark theme,
 * creates the styles and sets the theme apply
 * callbacks.
void Display_DarkThemeInit(void)
	 * Set the theme styles
	Display_DarkThemeStyleInit();
	 * Inititalise the theme (it will be built from the basic theme)
	DarkTheme = *(lv_theme_default_init(MyLCDDisplay, lv_palette_main(LV_PALETTE_NONE), lv_palette_main(LV_PALETTE_NONE), false, &lv_font_montserrat_14));
	 * Set the parent theme
	lv_theme_set_parent(&DarkTheme, lv_disp_get_theme(MyLCDDisplay));
	 * Set the theme apply callback
	lv_theme_set_apply_cb(&DarkTheme, Display_DarkThemeApply);
 * callbacks.
void Display_LightThemeInit(void)
	Display_LightThemeStyleInit();
	LightTheme = *(lv_disp_get_theme(MyLCDDisplay));
	lv_theme_set_parent(&LightTheme, lv_disp_get_theme(MyLCDDisplay));
	lv_theme_set_apply_cb(&LightTheme, Display_LightThemeApply);
This is where I create the styles for these themes
 * This function creates the styles for
 * the dark theme.
void Display_DarkThemeStyleInit(void)
	 * Base style for the dark theme
	lv_style_init(&Dark_base);
	lv_style_set_bg_color(&Dark_base, lv_color_hex(0x1d293b));
	lv_style_set_line_rounded(&Dark_base, 0);
	lv_style_set_border_color(&Dark_base, lv_color_hex(0xffffff));
	lv_style_set_text_color(&Dark_base, lv_color_hex(0x22d664));
	 * Style for focussed objects
	lv_style_init(&Dark_focussed);
	lv_style_set_bg_color(&Dark_focussed, lv_color_hex(0xcdd930));
 * the light theme.
void Display_LightThemeStyleInit(void)
		lv_style_init(&Light_base);
		lv_style_set_bg_color(&Light_base, lv_color_hex(0xdefffb));
		lv_style_set_line_rounded(&Light_base, 3);
		lv_style_set_text_color(&Light_base, lv_color_hex(0x443f73));
		 * Style for the focussed objects
		lv_style_init(&Light_focussed);
		lv_style_set_bg_color(&Light_focussed, lv_color_hex(0xd124d4));
		lv_style_set_text_color(&Light_focussed, lv_color_hex(0x78513c));
These are my theme apply callbacks
 * This function applies the dark theme
 * It will set all the style properties
 * for the objects.
	 * All objects get the base style
	lv_obj_add_style(obj, &Dark_base, 0);
	 * All objects get the focussed style
	lv_obj_add_style(obj, &Dark_focussed, LV_STATE_FOCUSED);
 * This function applies the light theme
 * for the objects.
static void Display_LightThemeApply(lv_theme_t * lightTheme, lv_obj_t * obj)
	 * All objects get the base theme
	lv_obj_add_style(obj, &Light_base, 0);
	lv_obj_add_style(obj, &Light_focussed, LV_STATE_FOCUSED);
Lastly, this function toggles between the two themes:
 * This function toggles between the light
 * and the dark themes.
void Display_ToggleDarkTheme(lv_event_t *e)
	if (lv_disp_get_theme(MyLCDDisplay) == &LightTheme)
		lv_disp_set_theme(MyLCDDisplay, &DarkTheme);
	else if (lv_disp_get_theme(MyLCDDisplay) == &DarkTheme)
		lv_disp_set_theme(MyLCDDisplay, &LightTheme);
Also need…
No solution yet ??
Where does the MyLCDDisplay structure come from?
