I have a fully working display and touch screen and have used to test many widgets. However, in building my project I noticed that the RAM being used seems excessive.
I am really enjoying this amazing library but need to reduce the RAM
Teensy 4.0 , Arduino IDE
8.0.2
Reduce the RAM on initialisation
By trial and error in removing lines of code I found that when the display is registered … code line  lv_disp_drv_register( &disp_drv ); the RAM moves a lot.
If there are no widgets in the sketch and I comment out this line the RAM goes down by 139,264 bytes. If there is a single example widget button_1 in the sketch and I comment out this line the RAM drops by 73,728 bytes.
So, is the problem with the initialisation/registration somehow? I am hoping this is some small oversight on my part as.
/*  #include "Arduino.h"
#include <SPI.h>
#include "DFRobot_Touch.h" //GT911 touch
#include <Wire.h>
#include <ILI9488_t3.h>
#include <lvgl.h>
#define TFT_DC  20
#define TFT_CS  10
#define TFT_RST 14
ILI9488_t3 display = ILI9488_t3(&SPI, TFT_CS, TFT_DC, TFT_RST);//from TFT_ILI9488_t3_colortest.ino
DFRobot_Touch_GT911 touch; // Touch
//Change to your screen resolution
static const uint32_t screenWidth  = 320;//480 for rot 3,320 for rot 2(but need to translate touch points)
static const uint32_t screenHeight = 480;//320 for rot 3, 480 for rot 2(but need to translate touch points)
static lv_color_t buf1[ screenWidth * /*10*/ 40 ];//declare screen buffer size
#if LV_USE_LOG != 0
// Serial debugging
void my_print( lv_log_level_t level, const char * file, uint32_t line, const char * fn_name, const char * dsc )
   Serial.printf( "%s(%s)@%d->%s\r\n", file, fn_name, line, dsc );
   Serial.flush();
// Display flushing ----taken from SKPang using ILI9488 screen driver
  uint16_t width = (area->x2 - area->x1 +1);
  uint16_t height = (area->y2 - area->y1+1);
  display.writeRect(area->x1, area->y1, width, height, (uint16_t *)color_p);
  lv_disp_flush_ready(disp); /* tell lvgl that flushing is done */
//Read the touchpad
uint16_t xpoint;//referenced to DFRobot_Touch.cpp
uint16_t ypoint;//referenced to DFRobot_Touch.cpp
int Touched;
int oldTouchX=0;
int oldTouchY=0;
void my_touchpad_read(lv_indev_drv_t * indev_driver, lv_indev_data_t * data)
  uint16_t touchX, touchY;
   if (Touched = 1)
     touchX = xpoint;//translate cap touch point to match TFT orientation...touchX=ypoint matches display.setRotation(3),touchX=xpoint matches display.setRotation(2)
     touchY = ypoint;//translate cap touch point to match TFT orientation...touchY=xpoint matches display.setRotation(3),touchY=ypoint matches display.setRotation(2)
     touchY = 480-touchY;//touchX=480-touchX matches display.setRotation(3),touchY=480-touchY matches display.setRotation(2)
     touchX = 320-touchX; //touchX=320-touchX matches display.setRotation(2)
    Serial.print("X= ");
    Serial.print(touchX);
    Serial.print(" Y= ");
    Serial.println(touchY);
    if ((touchX != oldTouchX) || (touchY != oldTouchY))
            oldTouchY = touchY;
            oldTouchX = touchX;
             //  data->state = touched ? LV_INDEV_STATE_PR : LV_INDEV_STATE_REL; //dont know what this does commented out by SKPang
                data->point.x = touchX;
                data->point.y = touchY;
  } else
        data->point.x = oldTouchX;
        data->point.y = oldTouchY;
        data->state =LV_INDEV_STATE_REL;
  return 0;
//================================ put static items for examples here ================================//
static void event_handler(lv_event_t * e)
        LV_LOG_USER("Clicked");
    else if(code == LV_EVENT_VALUE_CHANGED) {
        LV_LOG_USER("Toggled");
void setup()
   Serial.begin( 115200 ); // prepare for possible serial debug
   Serial.println( "Hello Arduino! (V8.0.X)" );
   Serial.println( "I am LVGL_Arduino" );
//    causes display to freeze at blue screen in set up
//#if LV_USE_LOG != 0
//   lv_log_register_print_cb( my_print ); // register print function for debugging
//#endif
  touch.begin();
  display.begin();
  display.setRotation(2); // (3)180, (2)90
  delay(100);
  display.fillScreen(ILI9488_BLUE);
   lv_disp_draw_buf_init( &draw_buf, buf1, NULL, screenWidth * /*10*/ 40 );//initialise the display buffer
   //Initialize the display
   //Change the following line to your display resolution
   //lv_disp_drv_register( &disp_drv );
   //Initialize the (dummy) input device driver
   lv_indev_drv_init( &indev_drv );
   lv_indev_drv_register( &indev_drv );
//======================= put void function from example here
 //================================  button_1 =================
    lv_obj_t * label;
    lv_obj_t * btn1 = lv_btn_create(lv_scr_act());
    lv_obj_add_event_cb(btn1, event_handler, LV_EVENT_ALL, NULL);
    lv_obj_align(btn1, LV_ALIGN_CENTER, 0, -40);
    label = lv_label_create(btn1);
    lv_obj_center(label);
    lv_obj_t * btn2 = lv_btn_create(lv_scr_act());
    lv_obj_add_event_cb(btn2, event_handler, LV_EVENT_ALL, NULL);
    lv_obj_align(btn2, LV_ALIGN_CENTER, 0, 40);
    lv_obj_add_flag(btn2, LV_OBJ_FLAG_CHECKABLE);
    lv_obj_set_height(btn2, LV_SIZE_CONTENT);
    label = lv_label_create(btn2);
    lv_label_set_text(label, "Toggle");
void loop()
    touch.scan();
    delay( 5 );
