My GUI seems having lots of objects. The builder (PlatformIO) sayings the RAM is reaching full. Sometimes the board is reset and the traceback debug saying related to memory allocation. If I reduce the objects in LVGL, the board stop reset & running fine.
Checking size .pio\build\esp32-s3-devkitc-1\firmware.elf
RAM: [======== ] 76.1% (used 249432 bytes from 327680 bytes)
Flash: [== ] 21.9% (used 731661 bytes from 3342336 bytes)
I tried to allocate the memory by a custom ESP32: define LV_MEM_POOL_ALLOC ps_malloc in lv_conf.h, it says fine the RAM is reduced from 76.1% to 36.1%. It is good however I afraid of the PSRAM is much slower than the internal RAM, so I do not thinking using the PSRAM option.
Instead I trying first to move some large data such as font / image definition into PSRAM or flash. In Arduino there is the PROGMEM keyword to do that but in LVGL the keyword in variable declaration is LV_ATTRIBUTE_LARGE_CONST. I cannot find any clear guide on the Internet about correct use of __attribute__ for my case, PlatformIO + VSCode + Arduino. What I tried so far was adding a new section like this:
#define LV_ATTRIBUTE_LARGE_CONST __attribute__ ((section(".psram_section")))
I found some “scripts” in ...\PlatformIO\packages\toolchain-xtensa-esp32s3\lib\ldscripts that mentioning the linker script with sections, but I don’t know how & where to set correct .psram_section that fits my target.
Please help. Thanks.
- ESP32-S3-DevKitC-1-N8R2 dual USB C - 8 MB Flash, 2 MB PSRAM
- Arduino with PlatformIO + VSCode
- Custom display driver for 8-bit 16 bpp parallel display, not using TFT_eSPI but myself code for LT7683 parallel LCD driver chip.
v8.3.9
Trying to save some space in RAM by putting large read only variables into other places.
If I replace the lv_conf.h
#undef LV_MEM_POOL_INCLUDE
#undef LV_MEM_POOL_ALLOC
with the custom PSRAM mem allocator for ESP32 lib (got these code on the Internet):
#ifdef ESP32
# if LV_MEM_ADR == 0
# define LV_MEM_POOL_INCLUDE <esp32-hal-psram.h>
# define LV_MEM_POOL_ALLOC ps_malloc
# endif
The estimated RAM consumming is saying countable low:
RAM: [==== ] 36.1% (used 118360 bytes from 327680 bytes)
Flash: [== ] 21.9% (used 731673 bytes from 3342336 bytes)
However, I afread of PSRAM is much slower than the internal RAM, so I trying to not use the PSRAM for all memory allocation.
#ifdef ESP32
# endif
And
