Help Needed: Manually created image does not display
I can display images stored as C files without issue, but when I try to display a manually generated image I get nothing. I tried the example on the LVGL documentation (v9 master branch) but the code shown there it does not work with Arduino:
static lv_image_dsc_t my_img_dsc = {
.header.always_zero = 0,
.header.w = 80,
.header.h = 60,
.data_size = 80 * 60 * LV_COLOR_DEPTH / 8,
.header.cf = LV_COLOR_FORMAT_NATIVE, /* Set the color format */
.data = my_img_data,
After much digging I found an alternate way of declaring manual images that does not result in errors when compiling on Arduino IDE, but again, I get no image:
static lv_img_dsc_t snap = {
0, //always_zero
18, //length of image
18, //width of image
LV_COLOR_FORMAT_RGB565,
648, //size of data
img_map, //data
Any help on troubleshooting this issue is appreciated! Thank you!
I am running the Arduino Giga and Giga Display on the latest Arduino IDE
v9
I need help fixing this code so that manually generated images can be displayed. Eventually, this code will be adapted so that a separate Arduino (connected to an ArduCam) can transfer an image to the Giga, which will store it as a uint_8_t and display it on the Giga Display.
I’ve tried looking through the LVGL documentation and forum for examples of displaying manually generated images and found no direct solution. As mentioned, my current code uses a modified form for declaring the lv image as the default method in the documentation yields errors on the Arduino compiler.
Declaring the image variable, the array should make an orange-colored 18x18 pixel square:
uint8_t img_map[] = {
  0x64, 0xf3, 0x64, 0xf3, 0x64, 0xf3, 0x64, 0xf3, 0x64, 0xf3, 0x64, 0xf3, 0x64, 0xf3, 0x64, 0xf3, 0x64, 0xf3, 0x64, 0xf3, 0x64, 0xf3, 0x64, 0xf3, 0x64, 0xf3, 0x64, 0xf3, 0x64, 0xf3, 0x64, 0xf3, 0x64, 0xf3, 0x64, 0xf3,
This code declares the img_dsc and attempts to display it:
      0, //always_zero
    648, //size of data
    img_map, //data
    lv_obj_t * img1 = lv_img_create(lv_scr_act());
    lv_img_set_src(img1, &snap);
    lv_obj_align(img1, LV_ALIGN_CENTER, 0, 0);
You might need to specify the .magic value
.magic = LV_IMAGE_HEADER_MAGIC,
