Demos are having underwhelming performance on an NXP i.MX 1170-EVK board. Particularly the “Widgets” and “Music” demos. When anything is moving, the CPU Usage skyrockets to almost 100% and the frame rate drops below 10.
Board: NXP MIMXRT1170-EVK (1 GHz Arm Cortex-M7 core + 400MHz Arm Cortex-M4 core)
Processor: MIMXRT1176DVMAA
IDE: MCUxpresso (v11.6.0_8187)
Compiler: GCC C
Language Standard: GNU C99
SDK: SDK_2.x_MIMXRT1170-EVK (v2.12.0)
Screen: Rocktech RK055HDMIPI4MA0 (720*1280 MIPI DSI Panel)
Version 8.2.0
Improve the performance of LVGL demos running on my board.
Using FreeRTOS vs. Baremetal (FreeRTOS is slightly better)
Change lv_config.h settings (Increase memory allotted, Increase/Decrease Refresh Periods)
Change FreeRTOSConfig.h (Increase total heap size, Increase/Decrease Tick Rate)
Enable NXP PXP (Pixel Pipeline Hardware Acceleration)
Enable Code Optimization -O3 (Slight Improvement)
Code is just the unmodified demo code included in the SDK.
Below is a video I took of the demo running on my board.
Below is a video of the same board and same screen running a different GUI, but the frames and CPU usage seem to be acceptable:
