My hello world demo, which works on 7.11.0, won’t build on 8.x. I’m getting some warnings about library stuff, but no errors about my own code, and then I just get this error:
"region `dram0_0_seg’ overflowed by 1301976 bytes
collect2: error: ld returned 1 exit status
*** [.pio/build/esp32-s3-devkitc-1-n8/firmware.elf] Error 1
ESP32, VS Code PlatformIO extension using Arduino platform and LVGL 8.3.7 (platformIO library)
I want to display “hello” then “world” and have the words change every second. Once it’s working, I’m going to migrate my remote controlled car dashboard to LVGL.
Updated lv_conf.h using the 8.x template, updated function calls to 8.x where appropriate.
I’ve spent days asking chatgpt and googling and reading everything I can. This is as stripped down as I can get it. I’m hoping I’m missing something obvious.
-I tried cleaning the library and rebuilding it, and I got an error that took me to a github page about too many rebuilds requested, which I didn’t understand.
#include <TFT_eSPI.h> // Include the graphics library
#include <lvgl.h>
#define LV_HOR_RES_MAX 240
#define LV_VER_RES_MAX 320
TFT_eSPI tft = TFT_eSPI(); /* Create instance of the TFT_eSPI class */
// Buffer for LittlevGL to draw
static lv_color_t buf[LV_HOR_RES_MAX * LV_VER_RES_MAX * 10]; // Declare a buffer for 10 lines
// Called by the LittlevGL library to write to the display // eSPI
void disp_flush(lv_disp_drv_t * disp, const lv_area_t * area, lv_color_t * color_p)
tft.startWrite();
tft.pushColors((uint16_t *)color_p, w * h, true);
tft.endWrite();
lv_disp_flush_ready(disp);
void lvgl_init() {
// Initialize LVGL
// Initialize your display buffer
lv_disp_draw_buf_init(&disp_buf, buf, NULL, LV_HOR_RES_MAX * 10);
// Initialize a display driver
lv_disp_drv_t disp_drv; /*Descriptor of a display driver*/
disp_drv.hor_res = LV_HOR_RES_MAX;
disp_drv.ver_res = LV_VER_RES_MAX;
disp_drv.flush_cb = disp_flush; /*Set your driver function*/
// disp_drv.buffer = &disp_buf; /*Assign the buffer to the display*/
lv_disp_drv_register(&disp_drv); /*Finally register the driver*/
// Initialize TFT
tft.begin();
tft.setRotation(3); // Use landscape orientation
lv_obj_t *label; // global
void create_hello_world_label() {
label = lv_label_create(lv_scr_act()); // create a label on the default (active) screen
lv_label_set_text(label, "Hello, world!"); // set the label text
lv_obj_center(label); // center the label on the screen
void setup() {
Serial.begin (115200); // Open serial port
// Initialize the display
lvgl_init();
create_hello_world_label();
// Add an array of words to cycle through
const char* words[] = {"Hello", "World", "ESP32", "Arduino", "LVGL"};
const int num_words = sizeof(words) / sizeof(words[0]); // Calculate the number of words
int word_index = 0; // Start with the first word
void update_hello_world_label(const char* word) {
lv_label_set_text(label, word); // Update the label text
lv_obj_align(label, LV_ALIGN_CENTER, 0, 0); // Re-center the label on the screen
unsigned long last_serial_time = millis();
unsigned long current_serial_time = last_serial_time;
unsigned long last_time = millis();
unsigned long current_time = last_time;
void loop() {
current_time = millis();
lv_tick_inc(current_time - last_time);
last_time = current_time;
// Update the display
lv_task_handler();
current_serial_time = millis();
if (current_serial_time - last_serial_time == 1000) {
last_serial_time = current_serial_time;
// Update the hello world text every second
word_index = (word_index + 1) % num_words; // Cycle through the words
update_hello_world_label(words[word_index]); // Update the label with the new word
delay(1); // Allow some delay for system tasks
