Hard fault migrating LVGL from 8.0 to 9.1 on a STM32H723ZGTx
I’m trying to migrate my LVGL 8.0 project currently running on a STM32H723ZGTx to the version 9.1. My project comprehend a display attached to the MCU, and the MCU itself has attached an external SRAM.
I’ve followed the new STM32 guide and also checked the Changelog.
I use the two display buffers for my screen, and this is my flush cb function.
void stm32_flush_cb(lv_disp_drv_t *disp_drv, const lv_area_t *area, lv_color_t *color_p) {
lv_disp_t *disp = _lv_refr_get_disp_refreshing();
lv_color_t *dma_xfer_src, *dma_xfer_dst;
HAL_LTDC_Reload(&hltdc, LTDC_RELOAD_VERTICAL_BLANKING);
dma_xfer_src = color_p;
if (color_p == framebuffer_1) {
dma_xfer_dst = framebuffer_2;
} else {
dma_xfer_dst = framebuffer_1;
for (size_t i = 0; i < disp->inv_p; i++) {
dma2d_copy_area(disp->inv_areas[i], (uint32_t)dma_xfer_src, (uint32_t)dma_xfer_dst);
Because in the 9.1 version there is no more invalidate areas field inside a `lv_disp_t (correct me if I’m wrong), I’ve changed the flush function by removing
This part isn’t necessary but it was an optimization, also mentioned in the faq
So, in my main.c after all the initialization functions added by STM32CubeMX, I’ve called lv_init() and my screen driver init function, that, before the changes for the 9.1 version, was
void screen_driver_init() {
static lv_disp_draw_buf_t draw_buf; //internal graphic buffer(s) called draw buffer(s)
lv_disp_draw_buf_init(&draw_buf, framebuffer_1, framebuffer_2, FRAMEBUFFER_SIZE);
lv_disp_drv_init(&lv_display_driver);
lv_display_driver.direct_mode = true;
lv_display_driver.hor_res = SCREEN_WIDTH;
lv_display_driver.ver_res = SCREEN_HEIGHT;
lv_display_driver.flush_cb = stm32_flush_cb;
lv_display_driver.draw_buf = &draw_buf;
lv_display_driver.dpi = 1;
lv_disp_drv_register(&lv_display_driver);
and now I changed to
lv_display_t * disp = lv_display_create(LCD_SCREEN_WIDTH, LCD_SCREEN_HEIGHT); /*Basic initialization with horizontal and vertical resolution in pixels*/
lv_display_set_flush_cb(disp, stm32_flush_cb); /*Set a flush callback to draw to the display*/
lv_display_set_buffers(disp, framebuffer_1, framebuffer_2, FRAMEBUFFER_SIZE, LV_DISPLAY_RENDER_MODE_PARTIAL); /*Set an initialized buffer*/
After that I’ve while(1) with refresh graphics function into it, with
lv_timer_handler();
Unfortunately, even if I’ve checked all the info about it, with this porting to lvgl version 9.1 the MCU goes in hard fault doing lv_timer_handler(). This is the stack trace
HardFault_Handler@0x08025caa
<signal handler called>@0xffffffe9 (Unknown Source:0)
lv_draw_rect@0x0800e4e4 (../lvgl-stm32/lvgl/src/draw/lv_draw_rect.c:182)
lv_obj_draw@0x0800643e (../lvgl-stm32/lvgl/src/core/lv_obj.c:479)
lv_obj_event_base@0x08007572 (../lvgl-stm32/lvgl/src/core/lv_obj_event.c:86)
event_send_core@0x080075b8 (../lvgl-stm32/lvgl/src/core/lv_obj_event.c:359)
lv_obj_send_event@0x0800763c (../lvgl-stm32/lvgl/src/core/lv_obj_event.c:64)
lv_obj_redraw@0x0800b272 (../lvgl-stm32/lvgl/src/core/lv_refr.c:110)
refr_obj_and_children@0x0800b7e2 (../lvgl-stm32/lvgl/src/core/lv_refr.c:790)
refr_area_part@0x0800b916 (../lvgl-stm32/lvgl/src/core/lv_refr.c:723)
refr_area@0x0800c03c (../lvgl-stm32/lvgl/src/core/lv_refr.c:650)
refr_invalid_areas@0x0800c03c (../lvgl-stm32/lvgl/src/core/lv_refr.c:566)
_lv_display_refr_timer@0x0800c03c (../lvgl-stm32/lvgl/src/core/lv_refr.c:374)
lv_timer_exec@0x0801969c (../lvgl-stm32/lvgl/src/misc/lv_timer.c:300)
lv_timer_handler@0x0801969c (../lvgl-stm32/lvgl/src/misc/lv_timer.c:105)
lv_timer_handler@0x0801969c (../lvgl-stm32/lvgl/src/misc/lv_timer.c:63)
refresh_graphics@0x080286c2 (../Core/UI/steering/graphics_manager.c:28)
main@0x0802592e (../Core/Src/main.c:198)
What could cause this hard fault? Before migrating to 9.1 version, all software and the display itself worked.
I’m using a STM32H723ZGTx and gcc to compile, using the STM32 for VSCode extension
v9.1.0-2-gcac17b580
Make the display working
Above
This is what the display is showinfg during the hard fault
