TL;DR: Calling lv_obj_add_state( ui_playBtn, LV_STATE_PRESSED ) does not change the appearance of a image button at runtime, but works during lvgl setup.
I’m using ESP-IDF to build an app running on a ESP32. While the GUI properly renders at startup, including the pressed status of the “play” button; it does not render status changes of the “play” and other buttons after startup, triggered by a separate FreeRTOS task on some events (turning a rotary encoder).
The main app structure (and LVGL setup) comes from the esp_lcd_ili9488 example, which works. The esp_lcd_ili9488 example has been (heavily) refactored of course, but the way LVGL and the SPI display are initialized is the same.
Does anyone have any idea what’s wrong in what I am doing?
MCU: ESP32-WROVER (Freenove)
DISPLAY: ILI9488 SPI, 480x320
ESP-IDF: 5.2
ESP Components:
atanisoft/esp_lcd_ili9488: 1.0.9 (esp component registry, project’s github)lvgl/lvgl: 8.3.11 (esp component registry)
8.3.11
Change the appearance of image buttons in the GUI when triggering the rotary encoder callback.
- moving
lv_tick_incfrom anesp_timer_start_periodiccallback to a separate FreeRTOS task in a loop withvTaskDelay - moving
lv_tick_incbasically everywhere (sorry for the lack of details) - sending
LV_EVENT_REFRESHevents to all buttons and to the root object - 2-3 more weeks of different attempts I lost track of
The code is sitting in this repo in the ui_logic branch:
- ILI9488 setup: /components/drabaioli__ili9488_display/ili9488_display.c
- LVGL initialization : /components/drabaioli__lvgl_ui/lvgl_ui.c
- LVGL ticker:
static void IRAM_ATTR lvgl_tick_cb(void *param)
lv_tick_inc(LVGL_UPDATE_PERIOD_MS);
void initialize_lvgl(...) {
ESP_LOGI(TAG, "Creating LVGL tick timer");
const esp_timer_create_args_t lvgl_tick_timer_args =
.callback = &lvgl_tick_cb,
.name = "lvgl_tick"
esp_timer_handle_t lvgl_tick_timer = NULL;
ESP_ERROR_CHECK(esp_timer_create(&lvgl_tick_timer_args, &lvgl_tick_timer));
ESP_ERROR_CHECK(esp_timer_start_periodic(lvgl_tick_timer, LVGL_UPDATE_PERIOD_MS * 1000));
- GUI setup (automatically generated with SquareLine Studio):
lv_obj_t * ui_Screen1;
lv_obj_t * ui_playBtn;
void ui_Screen1_screen_init(void)
ui_Screen1 = lv_obj_create(NULL);
lv_obj_clear_flag(ui_Screen1, LV_OBJ_FLAG_SCROLLABLE); /// Flags
ui_screenBackground = lv_obj_create(ui_Screen1);
ui_playBtn = lv_imgbtn_create(ui_Screen1);
lv_imgbtn_set_src(ui_playBtn, LV_IMGBTN_STATE_RELEASED, NULL, &ui_img_play_png, NULL);
lv_imgbtn_set_src(ui_playBtn, LV_IMGBTN_STATE_PRESSED, NULL, &ui_img_play_border_png, NULL);
void ui_init(void)
lv_disp_t * dispp = lv_disp_get_default();
lv_theme_t * theme = lv_theme_default_init(dispp, lv_palette_main(LV_PALETTE_BLUE), lv_palette_main(LV_PALETTE_RED),
true, LV_FONT_DEFAULT);
lv_disp_set_theme(dispp, theme);
ui_Screen1_screen_init();
lv_disp_load_scr(ui_Screen1);
- Setup initial UI state and update logic (works at startup, does not at runtime,
update_ui_componentsgets correctly triggered by rotary encoder callback, butlv_obj_add_statehas no effect):
static void update_ui_components( state_t * state )
lv_obj_clear_state( ui_playBtn, LV_STATE_PRESSED );
switch( state->active_component )
case PLAY_PAUSE:
lv_obj_add_state( ui_playBtn, LV_STATE_PRESSED );
ESP_LOGI( "DIEGO", "PLAY_PAUSE" );
lv_event_send( ui_playBtn, LV_EVENT_REFRESH, NULL );
break;
lv_event_send( ui_Screen1, LV_EVENT_REFRESH, NULL );
void app_main(void)
// Setup everything
while( 1 )
vTaskDelay( pdMS_TO_TICKS( 10 ) );
lv_timer_handler();
- rotary encoder position change callback:
static void IRAM_ATTR encoder_position_cb( position_event_t event )
// indirectly call update_ui_components
(top-left corner CPU usage gets updated, media player buttons don’t)
