Grouping element with title area
Please add such a widget to the list. I couldn’t make this thing using container or canvas. I’m specifically talking about item groupings (red, yellow, green) rectangles
rigol-dp1000-series-programmable-dc-power-supply
You can make this with panels and labels :slight_smile:
Here is SquareLine Studio file :wink:
Test.zip (35.6 KB)
Wow, it’s really interesting to share!
Thank you. The outer/inner rectangle should have round corners. also the rectangles should look 3D, not flat
Your welcome. This was just draft :wink: you can edit to your needs or not use it at all :slightly_smiling_face:
Yes, sure. You did 90% of the work. I was basically asking if it is possible or not.
Why SquareLine Studio does not support all LVGL widgets?
Sorry, did not get that. Rounded corners are not problem, 3D look will need more work and I would recommend to look at Thermostat example. There is also YT video about it :wink: . I made that screen, to try just if my idea would work, in like 10 - 15 minutes. SLS is really helpfull.
To be honest, I do not know. Look at forum and I think, that you will find some answers there :wink:
