Hello, I’m designing an interface as shown in the image. I’m having issues with the image quality. I designed the panel backgrounds in Photoshop. They have gradient color transitions. However, when I generate the code for LVGL, the gradient transitions are very noticeable. The image quality suffers. I’m using 16-bit RGB. I designed the interface and generated the code in Squareline Studio. How can I make the gradient transitions smoother?
Did you use the same colour mode in Photoshop as in LVGL? Having more bits per colour in Photoshop is one possible source for the banding.
Currently there is no dithering support in LVGL. That is what is going to be needed to fix the issue.
Here is some dithering code you can use…
#define CALC_THRESHOLD(x, y) (uint8_t)(((y & 7) << 3) + (x & 7))
uint8_t red_thresh[] = { 1, 7, 3, 5, 0, 8, 2, 6, 7, 1, 5, 3, 8, 0, 6, 2, 3, 5,
0, 8, 2, 6, 1, 7, 5, 3, 8, 0, 6, 2, 7, 1, 0, 8, 2, 6,
1, 7, 3, 5, 8, 0, 6, 2, 7, 1, 5, 3, 2, 6, 1, 7, 3, 5,
0, 8, 6, 2, 7, 1, 5, 3, 8, 0 };
uint8_t green_thresh[] = { 1, 3, 2, 2, 3, 1, 2, 2, 2, 2, 0, 4, 2, 2, 4, 0, 3, 1,
2, 2, 1, 3, 2, 2, 2, 2, 4, 0, 2, 2, 0, 4, 1, 3, 2, 2,
3, 1, 2, 2, 2, 2, 0, 4, 2, 2, 4, 0, 3, 1, 2, 2, 1, 3,
2, 2, 2, 2, 4, 0, 2, 2, 0, 4 };
uint8_t blue_thresh[] = { 5, 3, 8, 0, 6, 2, 7, 1, 3, 5, 0, 8, 2, 6, 1, 7, 8, 0,
6, 2, 7, 1, 5, 3, 0, 8, 2, 6, 1, 7, 3, 5, 6, 2, 7, 1,
5, 3, 8, 0, 2, 6, 1, 7, 3, 5, 0, 8, 7, 1, 5, 3, 8, 0,
6, 2, 1, 7, 3, 5, 0, 8, 2, 6 };
static inline void rgb565_dither_pixel(uint8_t treshold_id, uint16_t *pixel)
*pixel = (((((*pixel >> 8) & 0xF8) + red_thresh[treshold_id]) << 8) |
((((*pixel >> 3) & 0xFC) + green_thresh[treshold_id]) << 3) |
((((*pixel & 0x1F) << 3) + blue_thresh[treshold_id]) >> 3));
void flush_cb(lv_display_t *disp, lv_area_t *area, uint8_t *buf)
uint32_t start_x = (uint32_t)area->x1;
uint32_t start_y = (uint32_t)area->y1;
uint32_t end_x = (uint32_t)area->x2;
uint32_t end_y = (uint32_t)area->y2;
uint32_t width = end_x - start_x + 1;
uint32_t height = end_y - start_y + 1;
uint16_t *buf_16 = (uint16_t *)buf;
for (uint32_t y=0;y<height;y++) {
for uint32_t x=0;x<width;x++) {
rgb565_dither_pixel(CALC_THRESHOLD((x + start_x), (y + start_y)), buf_16);
buf_16++;
// write buffer data here.
