Not able to get a touch feedback while using LVGL
Nrf5340 MCU, Custom board, RM69090 Display controller (QSPI), 320%360 AMOLED display. Zephyr RTOS with Nordic NCS (SDK) with built-in gcc tools)
NCS version: 1.5.1
LVGL version: ## v7.6.1 (06.10.2020)
Zephyr RTOS version: 2.4.99
Just want to see touch getting detected
The touch driver works I can detect touch (finger down, up, move etc.), get x,y coordinates outside of LVGL. when I integrate with LVGL, display works fine, my touch driver detects a touch but LVGL doesn’t.
void btn_event_cb(lv_obj_t *btn, lv_event_t event) {
if (event == LV_EVENT_CLICKED) {
printf("Clicked\n");
void set_button(void) {
lv_obj_t *btn = lv_btn_create(lv_scr_act(), NULL); /*Add a button to the current screen*/
//lv_obj_set_pos(btn, 10, 10); /*Set its position*/
lv_obj_set_size(btn, 150, 100); /*Set its size*/
lv_obj_set_event_cb(btn, btn_event_cb); /*Assign a callback to the button*/
lv_obj_align(btn, NULL, LV_ALIGN_CENTER, 0, 60);
lv_obj_t *label = lv_label_create(btn, NULL); /*Add a label to the button*/
lv_label_set_text(label, "Next"); /*Set the labels text*/
/*Return true is the touchpad is pressed*/
static bool kbpro_lvgl_touchpad_is_pressed(void) {
return kbpro_touch_ztw622_event_status();
/*Get the x and y coordinates if the touchpad is pressed*/
static void kbpro_lvgl_touchpad_get_xy(lv_coord_t * x, lv_coord_t * y) {
(*x) = kbpro_touch_ztw622_get_x_coord();
(*y) = kbpro_touch_ztw622_get_y_coord();
/* Will be called by the LVGL library to read the touchpad */
static bool kbpro_lvgl_touchpad_read(lv_indev_drv_t * indev_drv, lv_indev_data_t * data)
static lv_coord_t last_x = 0;
static lv_coord_t last_y = 0;
if(kbpro_lvgl_touchpad_is_pressed()) {
kbpro_lvgl_touchpad_get_xy(&last_x, &last_y);
} else {
data->point.x = last_x;
data->point.y = last_y;
/*Return `false` because we are not buffering and no more data to read*/
return false;
initialize lvgl input device driver (touch in our case)
lv_indev_t * indev_touchpad;
lv_indev_drv_t indev_drv;
void kbpro_lvgl_indev_init(void) {
/*Initialize your touchpad if you have*/
#if KBPRO_ENABLE_TOUCH
kbpro_ztw622_touch_init();
kbpro_ztw622_touch_check_id();
#endif //KBPRO_ENABLE_TOUCH
indev_drv.read_cb = kbpro_lvgl_touchpad_read;
indev_touchpad = lv_indev_drv_register(&indev_drv);
if (!indev_touchpad) {
printk("\n kbpro_lvgl_indev_init FAIL");
