Board: Raspberry Pi 4B - 8Gb
OS: Ubuntu 22.04 Server
Screen: Waveshare 5" Circular LCD Touchscreen using HDMI. Resolution: 1080x1080
Compiler: Installed build-essential, using the provide Makefile
Very much at the start of my lvgl journey.
- Working version of lv_micropython
- Working version of lv_port_linux_frame_buffer
- Working keyboard
- Working mouse
- Working touchscreen
- Working LVGL UI elements
Currently none of the above is operating correctly and I need to get the basics before I start using Squareline Studio for my UI development
Installed the following in
/boot/firmware/config.txthdmi_group=2 hdmi_mode=87 hdmi_pixel_freq_limit=356000000 hdmi_timings=1080 0 68 32 100 1080 0 12 4 16 0 0 0 60 0 85500000 0based on the waveshare wiki for this screen. This got the screen responding to the board.
Installed lv_micropython in ~ following the exact procedure as defined in the GitHub README
Installed lv_port_linux_frame_buffer in ~ following the exact procedure as defined in the GitHub README
Made no changes to the lv_conf.h as found in the root directory of the lv_port_linux_frame_buffer clone as the defaults seemed appropriate
Made these changes to the lv_drv_conf.h found at that location
USE_EVDEV 1 EVDEV_HOR_MAX 1080 EVDEV_VER_MAX 1080 -
After compilation of the two resources I ran “demo” and was rewarded with the “Elana Smith” dialog in the top left of the screen. However as soon as it displays and error appears in the PuTTY window I’m using to access the rpi (see below). Additionally the screen and mouse were unresponsive and a blinking cursor created a small black blinking cursor block in the middle of the dialog. Using ‘enter’ on the keyboard overwrote the dialog with standard command line prompts.
unable to open evdev interface:: No such file or directory -
I successfully ran evtest for each device
- /dev/input/event0 caused touch events to scroll on the screen
- /dev/input/event1 captured and displayed the correct keys I was pressing on the keyboard
- /dev/input/event4 showed the values of the mouse moves, clicks and wheel movements
On reading the forums there were hints that SDL could be used so I tried the following settings in the lv_drv_conf.h
USE_EVDEV 0 USE_SDL 1 SDL_HOR_RES 1080 SDL_HOR_RES 1080 USE_FBDEV 1I also tried various include paths for SDL until I found it at
SDL_INCLUDE_PATH </usr/include/SDL2/SDL.h>The SDL version of the compilation did not go well with missing
#define M_PIand a slew of errors due to the compiler being unable to find SDL.h and thus various SDL functions which were needed.
I also tried an installation of xorg
Conclusion
I feel like I’m close but am now stuck as I do not have the depth of knowledge that you all do to take me through to a solution.
Any thoughts and/or questions would be gratefully received
Regards
Ian Carson
