How do I get the center of an object ?
Any. I’m using Micropython, but I gather this applies also to C.
I would like to get the center coordinates of an object. As far as I can tell the get_x
etc. method only gives coordinates relative to the enclosing object. Is there an API for that, or do I have to recurse through the objects until I get to the enclosing screen?
lv_obj_get_coords
should give you the object’s area relative to the screen. If you want the center point you can then get the midpoint between x1
and x2
, as well as y1
and y2
Thank you. I had not quite understood how get_coords
worked. Especially since I did not quite understand what was meant by area. So in Micropython someone could write something like:
ar = area_t()
obj.get_coords(ar)
x_mid = (ar.x1+ar.x2)//2
y_mid = (ar.y1+ar.y2)//2
One question though: are the two points described in area_t
the upper left/lower right points of the object? So one would have obj.get_width()
and ar.x2-ar.x1+1
equal?
