Get absolute pixel address in set_px_cb? (halftone fill)
I am implementing a halftone fill capability (for monochrome displays).
In lvgl 5.3 I did this by modifying the sw_color_fill function. halftone issue
In 5.3 the absolute address was passed in via mem_area
In 6.0 this function has changed parameters, how do I retrieve the absolute address of each pixel?
IMXRT1052
Halftone fill function
Modifying sw_color_file with the following code.
Here is part of the sw_color_file code I modified (this is using a relative address, row or col, not absolute)
static void sw_color_fill(lv_color_t * mem, lv_coord_t mem_width, const lv_area_t * fill_area, lv_color_t color, lv_opa_t opa)
    /*Set all row in vdb to the given color*/
    lv_coord_t row;
    lv_coord_t col;
    lv_disp_t * disp = lv_refr_get_disp_refreshing();
    if(disp->driver.set_px_cb) {
        for(col = fill_area->x1; col <= fill_area->x2; col++) {
            for(row = fill_area->y1; row <= fill_area->y2; row++) {
                disp->driver.set_px_cb(&disp->driver, (uint8_t *)mem, mem_width, col, row, color, opa);
    } else {
        mem += fill_area->y1 * mem_width; /*Go to the first row*/
        /*Run simpler function without opacity*/
        if(opa == LV_OPA_COVER) {
        else if(opa == LV_OPA_HALFTONE)
        	//printf("half: %d\n", opa);
            /*Fill the first two rows with halftone pattern*/
            	if(col % 2 == 0)
                    mem[col] = color;
            		mem[col] = LV_COLOR_BLACK;
            lv_color_t * mem_first = &mem[fill_area->x1];
            mem += mem_width;
            	if(col % 2 == 0)
            		mem[col] = color;
            /*Copy the correct row to all other rows*/
            lv_color_t * mem_second = &mem[fill_area->x1];
            lv_coord_t copy_size   = (fill_area->x2 - fill_area->x1 + 1) * sizeof(lv_color_t);
            mem += mem_width;
            for(row = fill_area->y1 + 2; row <= fill_area->y2; row++) {
            	if(row % 2 == 0)
                  memcpy(&mem[fill_area->x1], mem_first, copy_size);
                  memcpy(&mem[fill_area->x1], mem_second, copy_size);
                mem += mem_width;
        /*Calculate with alpha too*/
        else {
Here is a refined condition block for halftone fill, still not working, but closer:
		// calculate halftone fill
		else if (opa == LV_OPA_HALFTONE)
			lv_color_t *mem_curr = mem;
			for (row = fill_area->y1; row <= fill_area->y2; row++) {
				for (col = fill_area->x1; col <= fill_area->x2; col++) {
					if ((int) (mem_curr) % 4 == 0) {
					} else {
						mem[col] = color;
					mem_curr++;
				mem += mem_width;
The address becomes relative because of the varying mem_width, which causes a redraw to mismatch depending on the area.
Here is a screenshot to demonstrate, the mismatches are where the mouse pointer caused a redraw of the area:
Create your manual halttone function and regist to
disp->driver.set_px_cb instead of modifying sw_color_fill(...)
such as
void halftone_set_px_cb(struct _disp_drv_t * disp_drv,
                         uint8_t * buf, lv_coord_t buf_w,
                         lv_coord_t x, lv_coord_t y,
    // .... your hafttone handler
    // (x, y)  is current pixel
OK, I tried that as well… it still looks like x and y are relative to the area being filled, not the entire screen.
void halftone_set_px_cb(struct _disp_drv_t *disp_drv, uint8_t *buf,
		lv_coord_t buf_w, lv_coord_t x, lv_coord_t y, lv_color_t color,
		lv_opa_t opa) {
	bool scr_transp = false;
#if LV_COLOR_DEPTH == 32 && LV_COLOR_SCREEN_TRANSP
    scr_transp = disp->driver.screen_transp;
	lv_color_t *vdb_px_p = buf;
	vdb_px_p += y * buf_w + x;
	if (scr_transp == false) {
		if (opa == LV_OPA_COVER) {
			*vdb_px_p = color;
		} else if (opa == LV_OPA_HALFTONE) {
			printf("x:%d y:%d\n", x, y);
			if (x % 2 == 0) {
				if (y % 2 == 0) {
					*vdb_px_p = LV_COLOR_BLACK;
				} else {
					*vdb_px_p = color;
			} else {
				if (y % 2 != 0) {
				} else {
					*vdb_px_p = color;
		} else {
			*vdb_px_p = lv_color_mix(color, *vdb_px_p, opa);
	} else {
        *vdb_px_p = color_mix_2_alpha(*vdb_px_p, (*vdb_px_p).ch.alpha, color, opa);
TFT_Simulator
Parameters that are sent to the sw_color_fill(...) function,
they are already relative area, not entire screen.
Then the area in your manual halftone_set_px_cb() is relative area too.
I’ve tried on my system color16bit by the following code.
(Not sure on the monochrome system is worked or not. )
Code
void halftone_set_px_cb(struct _disp_drv_t * disp_drv, uint8_t * buf, lv_coord_t buf_w, lv_coord_t x, lv_coord_t y,
//  uint32_t* c = (uint32_t*)&buf[(x+y*buf_w)*4]; // color32bit
  uint16_t* c = (uint16_t*)&buf[(x+y*buf_w)*2];   // color16bit
//  uint8_t* c = (uint8_t*)&buf[(x+y*buf_w)];     // color8bit
  if( (x % 2 == 0 && y % 2 == 1) ||(x % 2 == 1 && y % 2 == 0) )
    color = LV_COLOR_BLACK;
  if( opa == LV_OPA_COVER) {
    *c = color.full;
  }else{
    lv_color_t color_buf; color_buf.full = *c;
    lv_color_t color_mix = lv_color_mix( color, color_buf, opa);
    *c = color_mix.full;
Result
capture_00018
Thanks for trying it!
It looks like it still suffers from the same problem, without the absolute coords, there is no guarantee that a pixel will be the same color every time and you get mismatches, on the edges of the buffer, during redraw, etc.
halftone_vid
OK, I used this method to get back to the absolute coordinates in the callback:
	lv_disp_t *disp = lv_refr_get_disp_refreshing();
	lv_disp_buf_t *vdb = lv_disp_get_buf(disp);
	//printf("abs x:%d y:%d\n", vdb->area.x1 + x, vdb->area.y1 + y);
	bool x_even = (vdb->area.x1 + x) % 2;
	bool y_even = (vdb->area.y1 + y) % 2;
	if ((x_even && y_even) || (!x_even && !y_even))
		*vdb_px_p = color;
halftone_vid2
@TridentTD I noticed a strange effect with the last image you posted:
It looks like every few lines the halftone fill is not being alternated correctly.
You can see it clearly in this picture:
Notice the two vertical pixels on the 11th and 12th rows.
That is also because of the relative coords (I assume) where the edges of the buffer are. You can see the same effect a bit in my animation before I fixed it with absolute coords.
Also, is this something that others would be interested in adding to the core library?
It is a fairly common way of adding variation to a monochrome display. I also added different halftone sizes, so instead of 1x1 squares, using larger 2x2, etc.
Ideally the OPA enumeration would be changed or another enumeration would be added for halftone, right now I “hijack” a couple of opacity values to designate halftone fill types, which requires changes to lv_color.h
@embeddedt
Yes, because of point(x,y) is relative point as @jking said.
This point(x,y) must turn to the absolute point by @jking’s code.
@jking
Because of the first parameter of callback is disp_drv_t.
Another technic for getting absolute point.
  bool x_even = ( disp_drv->buffer->area.x1 + x )%2;
  bool y_even = ( disp_drv->buffer->area.y1 + y )%2;
