After further experimentation I put in a clean install of LV_micropython.
Built and then ran my loop, NO ISSUES.
Then I copied my custom lv_config.h file and now the issue with garbage collection have surfaced.
What in the lv_config.h file could cause a gc.collect() issue
* @file lv_conf.h
* Configuration file for v9.0.0-dev
* Copy this file as `lv_conf.h`
* 1. simply next to the `lvgl` folder
* 2. or any other places and
* - define `LV_CONF_INCLUDE_SIMPLE`
* - add the path as include path
/* clang-format off */
#ifndef LV_CONF_H
#define LV_CONF_H
#include <stdint.h>
COLOR SETTINGS
/*Color depth: 1 (1 byte per pixel), 8 (RGB332), 16 (RGB565), 24 (RGB888), 32 (ARGB8888)*/
#define LV_COLOR_DEPTH 16
#define LV_COLOR_CHROMA_KEY lv_color_hex(0x00ff00)
STDLIB WRAPPER SETTINGS
/*Enable and configure the built-in memory manager*/
#define LV_USE_BUILTIN_MALLOC 1
#if LV_USE_BUILTIN_MALLOC
/*Size of the memory available for `lv_malloc()` in bytes (>= 2kB)*/
#define LV_MEM_SIZE (48U * 1024U) /*[bytes]*/
/*Size of the memory expand for `lv_malloc()` in bytes*/
#define LV_MEM_POOL_EXPAND_SIZE 0
#if LV_MEM_ADR == 0
#undef LV_MEM_POOL_INCLUDE
#undef LV_MEM_POOL_ALLOC
#endif /*LV_USE_BUILTIN_MALLOC*/
/*Enable lv_memcpy_builtin, lv_memset_builtin, lv_strlen_builtin, lv_strncpy_builtin, lv_strcpy_builtin*/
#define LV_USE_BUILTIN_MEMCPY 1
/*Enable and configure the built-in (v)snprintf */
#define LV_USE_BUILTIN_SNPRINTF 1
#if LV_USE_BUILTIN_SNPRINTF
#define LV_SPRINTF_USE_FLOAT 0
#endif /*LV_USE_BUILTIN_SNPRINTF*/
#define LV_STDLIB_INCLUDE <stdint.h>
#define LV_STDIO_INCLUDE <stdint.h>
#define LV_STRING_INCLUDE <stdint.h>
#define LV_MALLOC lv_malloc_builtin
#define LV_REALLOC lv_realloc_builtin
#define LV_FREE lv_free_builtin
#define LV_MEMSET lv_memset_builtin
#define LV_MEMCPY lv_memcpy_builtin
#define LV_SNPRINTF lv_snprintf_builtin
#define LV_VSNPRINTF lv_vsnprintf_builtin
#define LV_STRLEN lv_strlen_builtin
#define LV_STRNCPY lv_strncpy_builtin
#define LV_STRCPY lv_strcpy_builtin
#define LV_COLOR_EXTERN_INCLUDE <stdint.h>
#define LV_COLOR_MIX lv_color_mix
#define LV_COLOR_PREMULT lv_color_premult
#define LV_COLOR_MIX_PREMULT lv_color_mix_premult
HAL SETTINGS
/*Default display refresh, input device read and animation step period.*/
#define LV_DEF_REFR_PERIOD 33 /*[ms]*/
/*Use a custom tick source that tells the elapsed time in milliseconds.
*It removes the need to manually update the tick with `lv_tick_inc()`)*/
#define LV_TICK_CUSTOM 0
#if LV_TICK_CUSTOM
#define LV_TICK_CUSTOM_INCLUDE "Arduino.h" /*Header for the system time function*/
#define LV_TICK_CUSTOM_SYS_TIME_EXPR (millis()) /*Expression evaluating to current system time in ms*/
/*If using lvgl as ESP32 component*/
// #define LV_TICK_CUSTOM_INCLUDE "esp_timer.h"
// #define LV_TICK_CUSTOM_SYS_TIME_EXPR ((esp_timer_get_time() / 1000LL))
#endif /*LV_TICK_CUSTOM*/
/*Default Dot Per Inch. Used to initialize default sizes such as widgets sized, style paddings.
*(Not so important, you can adjust it to modify default sizes and spaces)*/
#define LV_DPI_DEF 130 /*[px/inch]*/
* DRAW CONFIGURATION
/*Enable the built in mask engine.
*Required to draw shadow, rounded corners, circles, arc, skew lines, or any other masks*/
#define LV_USE_DRAW_MASKS 1
#define LV_USE_DRAW_SW 1
#if LV_USE_DRAW_SW
/*Enable complex draw engine.
*Required to draw shadow, gradient, rounded corners, circles, arc, skew lines, image transformations or any masks*/
#define LV_DRAW_SW_COMPLEX 1
/* If a widget has `style_opa < 255` (not `bg_opa`, `text_opa` etc) or not NORMAL blend mode
* it is buffered into a "simple" layer before rendering. The widget can be buffered in smaller chunks.
* "Transformed layers" (if `transform_angle/zoom` are set) use larger buffers
* and can't be drawn in chunks. */
/*The target buffer size for simple layer chunks.*/
#define LV_DRAW_SW_LAYER_SIMPLE_BUF_SIZE (24 * 1024) /*[bytes]*/
/*Used if `LV_DRAW_SW_LAYER_SIMPLE_BUF_SIZE` couldn't be allocated.*/
#define LV_DRAW_SW_LAYER_SIMPLE_FALLBACK_BUF_SIZE (3 * 1024) /*[bytes]*/
/*Allow buffering some shadow calculation.
*LV_DRAW_SW_SHADOW_CACHE_SIZE is the max. shadow size to buffer, where shadow size is `shadow_width + radius`
*Caching has LV_DRAW_SW_SHADOW_CACHE_SIZE^2 RAM cost*/
#define LV_DRAW_SW_SHADOW_CACHE_SIZE 0
/* Set number of maximally cached circle data.
* The circumference of 1/4 circle are saved for anti-aliasing
* radius * 4 bytes are used per circle (the most often used radiuses are saved)
* 0: to disable caching */
#define LV_DRAW_SW_CIRCLE_CACHE_SIZE 4
/*Default gradient buffer size.
*When LVGL calculates the gradient "maps" it can save them into a cache to avoid calculating them again.
*LV_DRAW_SW_GRADIENT_CACHE_DEF_SIZE sets the size of this cache in bytes.
*If the cache is too small the map will be allocated only while it's required for the drawing.
*0 mean no caching.*/
#define LV_DRAW_SW_GRADIENT_CACHE_DEF_SIZE 0
/*Allow dithering the gradients (to achieve visual smooth color gradients on limited color depth display)
*LV_DRAW_SW_GRADIENT_DITHER implies allocating one or two more lines of the object's rendering surface
*The increase in memory consumption is (32 bits * object width) plus 24 bits * object width if using error diffusion */
#define LV_DRAW_SW_GRADIENT_DITHER 0
#if LV_DRAW_SW_GRADIENT_DITHER
/*Add support for error diffusion dithering.
*Error diffusion dithering gets a much better visual result, but implies more CPU consumption and memory when drawing.
*The increase in memory consumption is (24 bits * object's width)*/
#define LV_DRAW_SW_GRADIENT_DITHER_ERROR_DIFFUSION 0
/*Enable subpixel rendering*/
#define LV_DRAW_SW_FONT_SUBPX 0
#if LV_DRAW_SW_FONT_SUBPX
/*Set the pixel order of the display. Physical order of RGB channels. Doesn't matter with "normal" fonts.*/
#define LV_DRAW_SW_FONT_SUBPX_BGR 0 /*0: RGB; 1:BGR order*/
/*Use SDL renderer API*/
#define LV_USE_DRAW_SDL 0
#if LV_USE_DRAW_SDL
#define LV_DRAW_SDL_INCLUDE_PATH <SDL2/SDL.h>
/*Texture cache size, 8MB by default*/
#define LV_DRAW_SDL_LRU_SIZE (1024 * 1024 * 8)
/*Custom blend mode for mask drawing, disable if you need to link with older SDL2 lib*/
#define LV_DRAW_SDL_CUSTOM_BLEND_MODE (SDL_VERSION_ATLEAST(2, 0, 6))
* GPU CONFIGURATION
/*Use Arm's 2D acceleration library Arm-2D */
#define LV_USE_GPU_ARM2D 0
/*Use STM32's DMA2D (aka Chrom Art) GPU*/
#define LV_USE_GPU_STM32_DMA2D 0
#if LV_USE_GPU_STM32_DMA2D
/*Must be defined to include path of CMSIS header of target processor
e.g. "stm32f769xx.h" or "stm32f429xx.h"*/
#define LV_GPU_DMA2D_CMSIS_INCLUDE
/*Use GD32 IPA GPU
* This adds support for Image Processing Accelerator on GD32F450 and GD32F470 series MCUs
* NOTE: IPA on GD32F450 has a bug where the fill operation overwrites data beyond the
* framebuffer. This driver works around it by saving and restoring affected memory, but
* this makes it not thread-safe. GD32F470 is not affected. */
#define LV_USE_GPU_GD32_IPA 0
/*Use NXP's PXP GPU iMX RTxxx platforms*/
#define LV_USE_GPU_NXP_PXP 0
#if LV_USE_GPU_NXP_PXP
/*1: Add default bare metal and FreeRTOS interrupt handling routines for PXP (lv_gpu_nxp_pxp_osa.c)
* and call lv_gpu_nxp_pxp_init() automatically during lv_init(). Note that symbol SDK_OS_FREE_RTOS
* has to be defined in order to use FreeRTOS OSA, otherwise bare-metal implementation is selected.
*0: lv_gpu_nxp_pxp_init() has to be called manually before lv_init()
#define LV_USE_GPU_NXP_PXP_AUTO_INIT 0
/*Use NXP's VG-Lite GPU iMX RTxxx platforms*/
#define LV_USE_GPU_NXP_VG_LITE 0
/*Use SWM341's DMA2D GPU*/
#define LV_USE_GPU_SWM341_DMA2D 0
#if LV_USE_GPU_SWM341_DMA2D
#define LV_GPU_SWM341_DMA2D_INCLUDE "SWM341.h"
* FEATURE CONFIGURATION
* Logging
/*Enable the log module*/
#define LV_USE_LOG 0
#if LV_USE_LOG
*LV_LOG_LEVEL_TRACE A lot of logs to give detailed information
*LV_LOG_LEVEL_INFO Log important events
*LV_LOG_LEVEL_WARN Log if something unwanted happened but didn't cause a problem
*LV_LOG_LEVEL_ERROR Only critical issue, when the system may fail
*LV_LOG_LEVEL_USER Only logs added by the user
*LV_LOG_LEVEL_NONE Do not log anything*/
#define LV_LOG_LEVEL LV_LOG_LEVEL_WARN
#define LV_LOG_PRINTF 0
/*1: Enable print timestamp;
*0: Disable print timestamp*/
#define LV_LOG_USE_TIMESTAMP 1
#define LV_LOG_TRACE_MEM 1
#define LV_LOG_TRACE_TIMER 1
#define LV_LOG_TRACE_INDEV 1
#define LV_LOG_TRACE_DISP_REFR 1
#define LV_LOG_TRACE_EVENT 1
#define LV_LOG_TRACE_OBJ_CREATE 1
#define LV_LOG_TRACE_LAYOUT 1
#define LV_LOG_TRACE_ANIM 1
#define LV_LOG_TRACE_MSG 1
#endif /*LV_USE_LOG*/
* Asserts
/*Enable asserts if an operation is failed or an invalid data is found.
*If LV_USE_LOG is enabled an error message will be printed on failure*/
#define LV_USE_ASSERT_NULL 1 /*Check if the parameter is NULL. (Very fast, recommended)*/
#define LV_USE_ASSERT_MALLOC 1 /*Checks is the memory is successfully allocated or no. (Very fast, recommended)*/
#define LV_USE_ASSERT_STYLE 0 /*Check if the styles are properly initialized. (Very fast, recommended)*/
#define LV_USE_ASSERT_MEM_INTEGRITY 0 /*Check the integrity of `lv_mem` after critical operations. (Slow)*/
#define LV_USE_ASSERT_OBJ 0 /*Check the object's type and existence (e.g. not deleted). (Slow)*/
/*Add a custom handler when assert happens e.g. to restart the MCU*/
#define LV_ASSERT_HANDLER while(1); /*Halt by default*/
* Others
/*1: Show CPU usage and FPS count
* Requires `LV_USE_SYSMON = 1`*/
#define LV_USE_PERF_MONITOR 0
#if LV_USE_PERF_MONITOR
/*0: Displays performance data on the screen, 1: Prints performance data using log.*/
#define LV_USE_PERF_MONITOR_LOG_MODE 0
/*1: Show the used memory and the memory fragmentation
* Requires `LV_USE_BUILTIN_MALLOC = 1`
#define LV_USE_MEM_MONITOR 0
#if LV_USE_MEM_MONITOR
#define LV_USE_REFR_DEBUG 0
/*Maximum buffer size to allocate for rotation.
*Only used if software rotation is enabled in the display driver.*/
#define LV_DISP_ROT_MAX_BUF (10*1024)
/*Garbage Collector settings
*Used if lvgl is bound to higher level language and the memory is managed by that language*/
#define LV_ENABLE_GC 0
#if LV_ENABLE_GC != 0
#define LV_GC_INCLUDE "gc.h" /*Include Garbage Collector related things*/
#endif /*LV_ENABLE_GC*/
/*Default image cache size. Image caching keeps some images opened.
*If only the built-in image formats are used there is no real advantage of caching.
*With other image decoders (e.g. PNG or JPG) caching save the continuous open/decode of images.
*However the opened images consume additional RAM.
*0: to disable caching*/
#define LV_IMG_CACHE_DEF_SIZE 0
/*Number of stops allowed per gradient. Increase this to allow more stops.
*This adds (sizeof(lv_color_t) + 1) bytes per additional stop*/
#define LV_GRADIENT_MAX_STOPS 2
/* Adjust color mix functions rounding. GPUs might calculate color mix (blending) differently.
* 0: round down, 64: round up from x.75, 128: round up from half, 192: round up from x.25, 254: round up */
#define LV_COLOR_MIX_ROUND_OFS 0
* COMPILER SETTINGS
/*For big endian systems set to 1*/
#define LV_BIG_ENDIAN_SYSTEM 0
/*Define a custom attribute to `lv_tick_inc` function*/
#define LV_ATTRIBUTE_TICK_INC
/*Define a custom attribute to `lv_timer_handler` function*/
#define LV_ATTRIBUTE_TIMER_HANDLER
/*Define a custom attribute to `lv_disp_flush_ready` function*/
/*Required alignment size for buffers*/
#define LV_ATTRIBUTE_MEM_ALIGN_SIZE 1
/*Will be added where memories needs to be aligned (with -Os data might not be aligned to boundary by default).
* E.g. __attribute__((aligned(4)))*/
/*Attribute to mark large constant arrays for example font's bitmaps*/
/*Compiler prefix for a big array declaration in RAM*/
#define LV_ATTRIBUTE_LARGE_RAM_ARRAY
/*Place performance critical functions into a faster memory (e.g RAM)*/
#define LV_ATTRIBUTE_FAST_MEM
/*Export integer constant to binding. This macro is used with constants in the form of LV_<CONST> that
*should also appear on LVGL binding API such as Micropython.*/
#define LV_EXPORT_CONST_INT(int_value) struct _silence_gcc_warning /*The default value just prevents GCC warning*/
/*Extend the default -32k..32k coordinate range to -4M..4M by using int32_t for coordinates instead of int16_t*/
#define LV_USE_LARGE_COORD 0
* FONT USAGE
/*Montserrat fonts with ASCII range and some symbols using bpp = 4
*https://fonts.google.com/specimen/Montserrat*/
#define LV_FONT_MONTSERRAT_8 0
#define LV_FONT_MONTSERRAT_10 0
#define LV_FONT_MONTSERRAT_12 0
#define LV_FONT_MONTSERRAT_14 1
#define LV_FONT_MONTSERRAT_16 0
#define LV_FONT_MONTSERRAT_18 0
#define LV_FONT_MONTSERRAT_20 1
#define LV_FONT_MONTSERRAT_22 0
#define LV_FONT_MONTSERRAT_24 0
#define LV_FONT_MONTSERRAT_26 0
#define LV_FONT_MONTSERRAT_28 0
#define LV_FONT_MONTSERRAT_30 0
#define LV_FONT_MONTSERRAT_32 0
#define LV_FONT_MONTSERRAT_34 0
#define LV_FONT_MONTSERRAT_36 0
#define LV_FONT_MONTSERRAT_38 0
#define LV_FONT_MONTSERRAT_40 0
#define LV_FONT_MONTSERRAT_42 0
#define LV_FONT_MONTSERRAT_44 0
#define LV_FONT_MONTSERRAT_46 0
#define LV_FONT_MONTSERRAT_48 1
/*Demonstrate special features*/
#define LV_FONT_MONTSERRAT_12_SUBPX 0
#define LV_FONT_MONTSERRAT_28_COMPRESSED 0 /*bpp = 3*/
#define LV_FONT_DEJAVU_16_PERSIAN_HEBREW 0 /*Hebrew, Arabic, Persian letters and all their forms*/
#define LV_FONT_SIMSUN_16_CJK 0 /*1000 most common CJK radicals*/
/*Pixel perfect monospace fonts*/
#define LV_FONT_UNSCII_8 0
#define LV_FONT_UNSCII_16 0
/*Optionally declare custom fonts here.
*E.g. #define LV_FONT_CUSTOM_DECLARE LV_FONT_DECLARE(my_font_1) LV_FONT_DECLARE(my_font_2)*/
/*Always set a default font*/
#define LV_FONT_DEFAULT &lv_font_montserrat_14
/*Enable handling large font and/or fonts with a lot of characters.
*Compiler error will be triggered if a font needs it.*/
#define LV_FONT_FMT_TXT_LARGE 1
/*Enables/disables support for compressed fonts.*/
#define LV_USE_FONT_COMPRESSED 1
/*Enable drawing placeholders when glyph dsc is not found*/
#define LV_USE_FONT_PLACEHOLDER 1
* TEXT SETTINGS
* Select a character encoding for strings.
* - LV_TXT_ENC_UTF8
* - LV_TXT_ENC_ASCII
#define LV_TXT_BREAK_CHARS " ,.;:-_)]}"
/*If a word is at least this long, will break wherever "prettiest"
*To disable, set to a value <= 0*/
#define LV_TXT_LINE_BREAK_LONG_LEN 0
/*Minimum number of characters in a long word to put on a line before a break.
*Depends on LV_TXT_LINE_BREAK_LONG_LEN.*/
#define LV_TXT_LINE_BREAK_LONG_PRE_MIN_LEN 3
/*Minimum number of characters in a long word to put on a line after a break.
/*The control character to use for signalling text recoloring.*/
#define LV_TXT_COLOR_CMD "#"
/*Support bidirectional texts. Allows mixing Left-to-Right and Right-to-Left texts.
*The direction will be processed according to the Unicode Bidirectional Algorithm:
#define LV_USE_BIDI 0
#if LV_USE_BIDI
*`LV_BASE_DIR_LTR` Left-to-Right
*`LV_BASE_DIR_RTL` Right-to-Left
*`LV_BASE_DIR_AUTO` detect texts base direction*/
/*Enable Arabic/Persian processing
*In these languages characters should be replaced with an other form based on their position in the text*/
* WIDGETS
/*Documentation of the widgets: https://docs.lvgl.io/latest/en/html/widgets/index.html*/
#define LV_USE_ANIMIMG 1
#define LV_USE_ARC 1 /* cant remove build will fail*/
#define LV_USE_BAR 1 /* cant remove build will fail*/
#define LV_USE_BTN 1
#define LV_USE_BTNMATRIX 1
#define LV_USE_CALENDAR 1 /* cant remove build will fail*/
#if LV_USE_CALENDAR
#define LV_CALENDAR_WEEK_STARTS_MONDAY 0
#if LV_CALENDAR_WEEK_STARTS_MONDAY
#define LV_CALENDAR_DEFAULT_DAY_NAMES {"Mo", "Tu", "We", "Th", "Fr", "Sa", "Su"}
#else
#define LV_CALENDAR_DEFAULT_DAY_NAMES {"Su", "Mo", "Tu", "We", "Th", "Fr", "Sa"}
#define LV_CALENDAR_DEFAULT_MONTH_NAMES {"January", "February", "March", "April", "May", "June", "July", "August", "September", "October", "November", "December"}
#define LV_USE_CALENDAR_HEADER_ARROW 1
#define LV_USE_CALENDAR_HEADER_DROPDOWN 1
#endif /*LV_USE_CALENDAR*/
#define LV_USE_CANVAS 0
#define LV_USE_CHART 1 /* cant remove build will fail*/
#define LV_USE_CHECKBOX 0
#define LV_USE_COLORWHEEL 0
#define LV_USE_DROPDOWN 1 /*Requires: lv_label*/
#define LV_USE_IMG 1 /*Requires: lv_label*/
#define LV_USE_IMGBTN 0
#define LV_USE_KEYBOARD 1
#define LV_USE_LABEL 1
#if LV_USE_LABEL
#define LV_LABEL_TEXT_SELECTION 0 /*Enable selecting text of the label*/
#define LV_LABEL_LONG_TXT_HINT 0 /*Store some extra info in labels to speed up drawing of very long texts*/
#define LV_USE_LED 0
#define LV_USE_LINE 1
#define LV_USE_LIST 0
#define LV_USE_MENU 0
#define LV_USE_METER 0
#define LV_USE_MSGBOX 1
#define LV_USE_ROLLER 0 /*Requires: lv_label*/
#define LV_USE_SLIDER 0 /*Requires: lv_bar*/
#define LV_USE_SPAN 0
#if LV_USE_SPAN
#define LV_SPAN_SNIPPET_STACK_SIZE 64
#define LV_USE_SPINBOX 0
#define LV_USE_SPINNER 0
#define LV_USE_SWITCH 0
#define LV_USE_TEXTAREA 1 /*Requires: lv_label*/
#if LV_USE_TEXTAREA != 0
#define LV_TEXTAREA_DEF_PWD_SHOW_TIME 1500 /*ms*/
#define LV_USE_TABLE 0
#define LV_USE_TABVIEW 0
#define LV_USE_TILEVIEW 0
#define LV_USE_WIN 1
* THEMES
/*A simple, impressive and very complete theme*/
#if LV_USE_THEME_DEFAULT
/*0: Light mode; 1: Dark mode*/
#define LV_THEME_DEFAULT_DARK 0
/*1: Enable grow on press*/
#define LV_THEME_DEFAULT_GROW 1
/*Default transition time in [ms]*/
#define LV_THEME_DEFAULT_TRANSITION_TIME 80
#endif /*LV_USE_THEME_DEFAULT*/
/*A very simple theme that is a good starting point for a custom theme*/
#define LV_USE_THEME_BASIC 1
/*A theme designed for monochrome displays*/
#define LV_USE_THEME_MONO 1
* LAYOUTS
/*A layout similar to Flexbox in CSS.*/
#define LV_USE_FLEX 1
/*A layout similar to Grid in CSS.*/
#define LV_USE_GRID 1
* 3RD PARTS LIBRARIES
/*File system interfaces for common APIs */
/*API for fopen, fread, etc*/
#define LV_USE_FS_STDIO 0
#if LV_USE_FS_STDIO
#define LV_FS_STDIO_LETTER '\0' /*Set an upper cased letter on which the drive will accessible (e.g. 'A')*/
#define LV_FS_STDIO_PATH "" /*Set the working directory. File/directory paths will be appended to it.*/
#define LV_FS_STDIO_CACHE_SIZE 0 /*>0 to cache this number of bytes in lv_fs_read()*/
/*API for open, read, etc*/
#define LV_USE_FS_POSIX 0
#if LV_USE_FS_POSIX
#define LV_FS_POSIX_LETTER '\0' /*Set an upper cased letter on which the drive will accessible (e.g. 'A')*/
#define LV_FS_POSIX_PATH "" /*Set the working directory. File/directory paths will be appended to it.*/
#define LV_FS_POSIX_CACHE_SIZE 0 /*>0 to cache this number of bytes in lv_fs_read()*/
/*API for CreateFile, ReadFile, etc*/
#define LV_USE_FS_WIN32 0
#if LV_USE_FS_WIN32
#define LV_FS_WIN32_LETTER '\0' /*Set an upper cased letter on which the drive will accessible (e.g. 'A')*/
#define LV_FS_WIN32_PATH "" /*Set the working directory. File/directory paths will be appended to it.*/
#define LV_FS_WIN32_CACHE_SIZE 0 /*>0 to cache this number of bytes in lv_fs_read()*/
#define LV_USE_FS_FATFS 0
#if LV_USE_FS_FATFS
#define LV_FS_FATFS_LETTER '\0' /*Set an upper cased letter on which the drive will accessible (e.g. 'A')*/
/*PNG decoder library*/
#define LV_USE_PNG 0
/*BMP decoder library*/
#define LV_USE_BMP 0
/* JPG + split JPG decoder library.
* Split JPG is a custom format optimized for embedded systems. */
#define LV_USE_SJPG 0
/*GIF decoder library*/
#define LV_USE_GIF 0
/*QR code library*/
#define LV_USE_QRCODE 0
/*Barcode code library*/
#define LV_USE_BARCODE 0
/*FreeType library*/
#define LV_USE_FREETYPE 0
#if LV_USE_FREETYPE
/*Memory used by FreeType to cache characters [bytes]*/
#define LV_FREETYPE_CACHE_SIZE (64 * 1024)
/*Let FreeType to use LVGL memory and file porting*/
#define LV_FREETYPE_USE_LVGL_PORT 0
/* 1: bitmap cache use the sbit cache, 0:bitmap cache use the image cache. */
/* sbit cache:it is much more memory efficient for small bitmaps(font size < 256) */
/* if font size >= 256, must be configured as image cache */
#define LV_FREETYPE_SBIT_CACHE 0
/* Maximum number of opened FT_Face/FT_Size objects managed by this cache instance. */
/* (0:use system defaults) */
#define LV_FREETYPE_CACHE_FT_FACES 4
#define LV_FREETYPE_CACHE_FT_SIZES 4
/* Built-in TTF decoder */
#define LV_USE_TINY_TTF 0
#if LV_USE_TINY_TTF
/* Enable loading TTF data from files */
#define LV_TINY_TTF_FILE_SUPPORT 0
/*Rlottie library*/
#define LV_USE_RLOTTIE 0
/*FFmpeg library for image decoding and playing videos
*Supports all major image formats so do not enable other image decoder with it*/
#define LV_USE_FFMPEG 0
#if LV_USE_FFMPEG
/*Dump input information to stderr*/
#define LV_FFMPEG_DUMP_FORMAT 0
* OTHERS
/*1: Enable API to take snapshot for object*/
#define LV_USE_SNAPSHOT 0
/*1: Enable system monitor component*/
#define LV_USE_SYSMON 0
/*1: Enable the runtime performance profiler*/
#define LV_USE_PROFILER 0
#if LV_USE_PROFILER
/*1: Enable the built-in profiler*/
#define LV_USE_PROFILER_BUILTIN 1
#if LV_USE_PROFILER_BUILTIN
/*Default profiler trace buffer size*/
#define LV_PROFILER_BUILTIN_BUF_SIZE (16 * 1024) /*[bytes]*/
/*Header to include for the profiler*/
#define LV_PROFILER_INCLUDE "lvgl/src/misc/lv_profiler_builtin.h"
/*Profiler start point function*/
#define LV_PROFILER_BEGIN LV_PROFILER_BUILTIN_BEGIN
/*Profiler end point function*/
#define LV_PROFILER_END LV_PROFILER_BUILTIN_END
/*1: Enable Monkey test*/
#define LV_USE_MONKEY 0
/*1: Enable grid navigation*/
#define LV_USE_GRIDNAV 0
/*1: Enable lv_obj fragment*/
#define LV_USE_FRAGMENT 0
/*1: Support using images as font in label or span widgets */
#define LV_USE_IMGFONT 0
#if LV_USE_IMGFONT
/*Imgfont image file path maximum length*/
#define LV_IMGFONT_PATH_MAX_LEN 64
/*1: Use img cache to buffer header information*/
#define LV_IMGFONT_USE_IMG_CACHE_HEADER 0
/*1: Enable a published subscriber based messaging system */
#define LV_USE_MSG 0
/*1: Enable Pinyin input method*/
/*Requires: lv_keyboard*/
#define LV_USE_IME_PINYIN 0
#if LV_USE_IME_PINYIN
/*1: Use default thesaurus*/
/*If you do not use the default thesaurus, be sure to use `lv_ime_pinyin` after setting the thesauruss*/
#define LV_IME_PINYIN_USE_DEFAULT_DICT 1
/*Set the maximum number of candidate panels that can be displayed*/
/*This needs to be adjusted according to the size of the screen*/
#define LV_IME_PINYIN_CAND_TEXT_NUM 6
/*Use 9 key input(k9)*/
#define LV_IME_PINYIN_USE_K9_MODE 1
#if LV_IME_PINYIN_USE_K9_MODE == 1
#define LV_IME_PINYIN_K9_CAND_TEXT_NUM 3
#endif // LV_IME_PINYIN_USE_K9_MODE
/*1: Enable file explorer*/
/*Requires: lv_table*/
#define LV_USE_FILE_EXPLORER 0
#if LV_USE_FILE_EXPLORER
/*Maximum length of path*/
#define LV_FILE_EXPLORER_PATH_MAX_LEN (128)
/*Quick access bar, 1:use, 0:not use*/
/*Requires: lv_list*/
#define LV_FILE_EXPLORER_QUICK_ACCESS 1
* DEVICES
/*Use SDL to open window on PC and handle mouse and keyboard*/
#define LV_USE_SDL 0
#if LV_USE_SDL
#define LV_SDL_INCLUDE_PATH <SDL2/SDL.h>
#define LV_SDL_PARTIAL_MODE 0 /*Recommended only to emulate a setup with a display controller*/
#define LV_SDL_FULLSCREEN 0
#define LV_SDL_DIRECT_EXIT 1 /*1: Exit the application when all SDL widows are closed*/
/*Driver for /dev/fb*/
#define LV_USE_LINUX_FBDEV 0
#if LV_USE_LINUX_FBDEV
#define LV_LINUX_FBDEV_BSD 0
/*Driver for /dev/dri/card*/
#define LV_USE_LINUX_DRM 0
/*Interface for TFT_eSPI*/
#define LV_USE_TFT_ESPI 0
* EXAMPLES
/*Enable the examples to be built with the library*/
#define LV_BUILD_EXAMPLES 0 /* cant remove build will fail*/
* DEMO USAGE
/*Show some widget. It might be required to increase `LV_MEM_SIZE` */
#define LV_USE_DEMO_WIDGETS 0
#if LV_USE_DEMO_WIDGETS
#define LV_DEMO_WIDGETS_SLIDESHOW 0
/*Demonstrate the usage of encoder and keyboard*/
#define LV_USE_DEMO_KEYPAD_AND_ENCODER 0
/*Benchmark your system*/
#define LV_USE_DEMO_BENCHMARK 0
#if LV_USE_DEMO_BENCHMARK
/*Use RGB565A8 images with 16 bit color depth instead of ARGB8565*/
#define LV_DEMO_BENCHMARK_RGB565A8 0
/*Stress test for LVGL*/
#define LV_USE_DEMO_STRESS 0
/*Music player demo*/
#define LV_USE_DEMO_MUSIC 0
#if LV_USE_DEMO_MUSIC
#define LV_DEMO_MUSIC_SQUARE 0
#define LV_DEMO_MUSIC_LANDSCAPE 0
#define LV_DEMO_MUSIC_ROUND 0
#define LV_DEMO_MUSIC_LARGE 0
#define LV_DEMO_MUSIC_AUTO_PLAY 0
/*Flex layout demo*/
#define LV_USE_DEMO_FLEX_LAYOUT 0
/*--END OF LV_CONF_H--*/
#endif /*LV_CONF_H*/
