I’m wondering if it would be possible to enter/exit a screen using an animation that does two things:
Split the screen into two objects, right down the middle, so a left side object and a right side object.
when the screen is called, the objects will slide in each from their own side, so the left object slides in from the left, and the right object slides in from the right.
While the object slides in/out, It would also be nice to fade in/out, so it would give a nice visual affect.
Is this something that can be done with the animations?
@kisvegabor this is great, thanks for the link!
Although you mentioned that it can be used to animate a screen, can I run two animations simultaneously on two main objects in the screen?
