When upgrading my Arduino ESP32 project from v7 to v8 lvgl I get a compile error on fonts which are created by the font converter.
Arduino ESP32
Complile code
* PUBLIC FONT
/*Initialize a public general font descriptor*/
#if LV_VERSION_CHECK(8, 0, 0)
const lv_font_t FreeSansOblique32 = {
#else
.get_glyph_dsc = lv_font_get_glyph_dsc_fmt_txt, /*Function pointer to get glyph's data*/
.get_glyph_bitmap = lv_font_get_bitmap_fmt_txt, /*Function pointer to get glyph's bitmap*/
.line_height = 28, /*The maximum line height required by the font*/
.base_line = 5, /*Baseline measured from the bottom of the line*/
#if !(LVGL_VERSION_MAJOR == 6 && LVGL_VERSION_MINOR == 0)
.subpx = LV_FONT_SUBPX_NONE,
#if LV_VERSION_CHECK(7, 4, 0)
.underline_position = -6,
.underline_thickness = 2,
.dsc = &font_dsc /*The custom font data. Will be accessed by `get_glyph_bitmap/dsc` */
## Screenshot and/or video
FreeSansOblique32.cpp:338: sorry, unimplemented non-trivial designated initializers not supported
