ForgeUI Studio — Browser-Based ESP32-P4 LVGL UI Builder, Now with Local AI GPU Generation
Hi everyone! :waving_hand:
I’m an independent developer from New Zealand, and I wanted to share an update on a project I’ve been building called ForgeUI Studio.
The goal is to make embedded touchscreen development easier by combining a browser-based visual UI editor, LVGL-based firmware generation and AI-assisted interface design.
What’s working so far?
ForgeUI Studio lets developers create and edit touchscreen interfaces visually, position widgets on a canvas, configure supported properties and work towards firmware for supported ESP32 display hardware.
My main development target has been the ESP32-P4, including the Waveshare 7-inch touchscreen.
:rocket: Meet Larry GPU — Our New AI Teammate
Recently, I integrated a locally hosted NVIDIA RTX 4080 running an experimental AI assistant called Larry GPU.
Larry can take a natural-language prompt such as:
“Build a premium marine dashboard with engine temperatures, navigation, battery monitoring and controls.”
He generates an editable UI proposal using ForgeUI’s certified widgets.
Studio validates the proposal, and the developer can open it in the visual editor to move, resize, delete or refine the components.
I’ve been testing him with:
  • Marine navigation dashboards
  • Coffee-machine interfaces
  • Smart-home and hotel-room controllers
  • Aircraft cockpit concepts
  • Retail checkout interfaces
These are real Studio-generated UI drafts, not finished hardware-connected applications.
:hammer_and_wrench: Still Experimental — And Improving
Larry GPU is very new, and we’re actively improving his layout quality and widget support.
Sometimes he gets spacing wrong or overlaps components. Rather than expecting perfect AI output, the idea is to give developers a useful starting point they can refine.
Studio currently has 81 registered widget types, while Larry’s certified AI composition toolbox exposes 21. We’re investigating how to safely expand that selection.
The GPU inference runs on my own RTX 4080 and communicates with Studio through an authenticated private connection.
I’d Love Some LVGL Developer Feedback
I’m particularly interested in what experienced LVGL developers think about this approach.
Would a visual editor combined with locally hosted AI-generated layouts be useful in your workflow?
Which LVGL widgets or ESP32 display features would you most want supported?
You can see ForgeUI Studio and real examples of Larry’s work here:
:globe_with_meridians: https://forgeui.co.nz/
:laptop: https://studio.forgeui.co.nz/
Still plenty to build, but it’s been exciting seeing this come together.
Constructive feedback, technical questions and suggestions are very welcome.
Cheers from New Zealand! :new_zealand:
Awesome, great job
Hi Rachel,
Thanks for taking a proper look and asking these questions. They’re exactly the things that matter when deciding whether a UI tool will fit a real embedded project.
Standalone LVGL C export
Yes—the generated interface exports as native LVGL C, and the exported project can be built outside Studio. Studio is the design and generation environment; it isn’t required to remain connected for the resulting firmware to run.
There are still the normal embedded dependencies: the appropriate LVGL version, board support, display and touch drivers, and any assets or helper code used by the interface. “Standalone” means independent of the hosted Studio, rather than a single C file with no supporting dependencies.
The build and flash workflow has been tested on Waveshare ESP32-P4 and ESP32-S3 7-inch boards, a Guition 10.1-inch P4 board, and an Elecrow CrowPanel 7-inch S3. That gives us real hardware evidence, although it isn’t a claim that every arbitrary board configuration is already supported.
Different screen sizes
Your concern about pixel positioning is fair. The current workflow is to design against the target display resolution and orientation, then inspect and adjust the layout for that target.
I wouldn’t promise that a dashboard designed at 1024×600 will automatically become a good 480×272 interface. Shrinking everything proportionally can leave text unreadable and touch targets too small. A smaller display often needs a different arrangement, fewer items per screen, or additional pages.
Larry can help with creating and editing the layout, but that doesn’t remove the need to review the result at the actual target resolution. I don’t want to imply that automatic responsive reflow across those sizes is already a solved feature.
The 21-widget toolbox
I should clarify the terminology here: the certified toolbox refers to the subset admitted to Larry’s composition workflow, rather than the entire Studio widget library.
A widget being available in the editor, having LVGL export support, and being certified for Larry to create and configure are separate things. Chart and TabView have had native export/runtime work, but that alone doesn’t establish that they are certified in the current Larry composition path.
I’ll check the current registry and follow up with the exact list and the specific status of Chart and TabView. Your point is well made: those capabilities are much more useful to assess than a headline widget count.
Validation and editable results
Larry’s output is intended to become editable Studio content. The workflow is to generate a proposal, review it, apply it to the canvas, and then continue with normal editing and Undo.
We’ve also tested connected behaviour: Larry has created Switch→LED pairs that were applied and exercised in the simulator, including ten independent pairs in one project.
Validation helps catch structural and connection errors, but it doesn’t prove that every spacing or usability decision is good. The generated result still needs visual review, simulator testing and, ultimately, testing on the target hardware.
Thanks again for the thoughtful feedback. It helps identify where the documentation needs to be more precise about what is supported today.
Scott
Creator & Lead Developer
ForgeUI Studio — New Zealand
Just to add some practical detail on the standalone export: exported projects include the BSP for the selected board, including its board-specific display and touch configuration.
We’ve verified the full round trip: export from Studio → open the exported project in VS Code → build locally with ESP-IDF → flash it back onto the physical board.
The resulting firmware runs independently of Studio. This has been tested through an actual local build and reflash, rather than only checking the generated source.
The I/O side has also been tested and debugged through the VS Code workflow, with physical input/output behaviour checked on hardware.
So you can use Studio to design and generate the project, then continue development, debugging and flashing locally in VS Code.
Scott
ForgeUI Studio
