Hi here,
I’m experimenting a weird bug with my Lvl_pc_simulator. If my app his launched as a debug session, all the screen are displayed correctly. If it’s not then only the 1st screen his displayed but never updated.
So here my question.
How do you force refresh / redraw the screen ?
I tryed a combinaison of lv_obj_invalidate + lv_refr_now. but this doesn’t seem to do the trick.
Here is my code sample
struct View {
bool _quit;
unsigned int _timeout;
lv_obj_t* _lvglBaseView;
lv_group_t* _group;
void mainLoop(View* view) {
if (view) {
_currentView = view;
_currentView->_quit = false;
unsigned long prevTick = getSystemTick();
unsigned long timeoutTick = prevTick + (static_cast<unsigned long>(_currentView->_timeout)/10);
// try to force refresh here
//lv_obj_refresh_ext_draw_pad()
lv_obj_invalidate(_currentView->_lvglBaseView);
lv_refr_now(lv_obj_get_disp(_currentView->_lvglBaseView));
while (timeoutTick >= prevTick && _currentView->_quit == false) {
delay_ms(10); //yield
lv_task_handler();
unsigned long newTick = getSystemTick();
lv_tick_inc((prevTick - newTick)*10);
prevTick = newTick;
_currentView = 0;
It’s very rare that you should need to manually invalidate the screen. Usually, it’s only needed in special cases to remove tearing artifacts from slow display.
I suspect the issue is with the way you are calling lv_tick_inc. It should not be called in the same loop as lv_task_handler (it needs to be called in parallel).
I suggest creating a separate thread to run lv_tick_inc or configuring LV_TICK_CUSTOM so you don’t need to call it at all.
lv_obj_invalidate is the only way to get an object to be redrawn. You shouldn’t need to call lv_refr_now as lv_task_handler will call that automatically.
The most common reason why refreshing doesn’t work is that lv_tick_inc doesn’t get called. I assume _tickThreadContinue is true?
Yes is true.
So I did more test and the display is OK when I’m using a small project but doesn’t with the real one except on a “debug session”.
Now I did add some printf in the “disp_drv.flush_cb”
I get called so I assume LVGL do his part OK. but SDL2 doesn’t refresh anything.
Or is it possible that the video_buffer that LVGL has sent me was the previous image again and again ? thus the no change ?
I manage to fix it, via letting the SDL driver more time to initialize.
It’s a bit overcustom use, but since we have no animation we don’t call lv_task_handler this frequently.
It’s basically a while(displayView) lv_task_handler();
Where displayView is altered by event or timeout…
Anyway in case someone have this issue, the fix is to let SDL do some lv_task_handler() for some little time before continuing.
Ofc if you have the regular case it’s all fine.
