Manually Force the Display Update
ESP32 ILI9341 with SPI Interface
8.3.4
Some part of my software is blocking in nature, it takes a lot of time actually to execute, let’s say 5 seconds.
My understanding unless lv_task_handler(); function is called display will not be updated.
My situation is, the microcontroller starts, and it processes something which takes around 5 seconds, and before calling this blocking function I want to display a wait message using a message box so that the user is aware that something is happening.
I tried calling the function lv_refr_now(NULL); but this doesn’t work, and similarly, I tried calling the function lv_task_handler directly.
I know I am doing something wrong, and there must be something available for this, which I couldn’t find.
I think the whole code is not needed, but I will share some important parts with comments.
The following function is called when someone presses the “Re-Scan” button.
void ReScanWiFiSSID(lv_event_t * e)
static lv_obj_t *msg_box;
// a message box object is created, which is used to display a message to the user
// that some processing is happening in the background and one should wait
msg_box = lv_msgbox_create( NULL, "Re-Scanning", \
"Please Wait, getting WiFi SSID", \
NULL, false );
lv_obj_center(msg_box);
// I added these to function, I thought this forced the display update, but this is not the case
lv_refr_now(NULL);
// lv_task_handler();
// these two functions are functions which take around 5 seconds of time
WiFi_Init();
WiFi_ScanSSID();
// and once this function execution is completed, the msg box is closed
lv_msgbox_close( msg_box );
But I can’t see the msg box, and the reason is clear to me, I created the msg box, closes the msg box and then LVGL works and for it, and nothing changed.
If I comment the line lv_msgbox_close( msg_box ); then I can see the message box after 5 seconds, but this is not what I wanted.
Let me know if some more information is needed.
