In my dropdown list I have set the selected option’s background to be slightly darker than the rest. I use the function lv_color_darken(lv_color_hex(0xf1f1f1), 10) to make the color. My problem is that the font is suddenly appearing quite choppy compared to the rest. Is this a “bug” or just something to be expected? It might just be because the colors are to alike but I wanted to check
Simulator
The newest to my knowledge
I would like to know why the text is so “rough” and if there is a way to fix it.
I think this is another manifestation of an LVGL bug where text gets drawn twice in some spots. AFAIK this case was fixed in v8 but I don’t think the fix was backported to v7.
I think i might have fixed it, or at least I have found what’s causing the problem: here
I just commented one of the draw_box_label functions out, but maybe there’s just missing an else and some brackets. I’m not too sure, but that might be the fix
@embeddedt. I did some testing before sending a PR and the else with brackets unfortunately didn’t fix the problem. After tinkering around I haven’t come up with a “clean” fix, it seems that lv_dropdown_page_design() is called twice with the mode being LV_DESIGN_DRAW_POST, or so I imagine at least. I’m lacking insight right now but I’ll try and see if something else seemingly obvious appears
Might this line: here just be redundant? If I comment out the line it seems to work perfectly normal, but on the other hand I don’t really know what the “intent” is behind that function, other than it gets called periodically when the dropdown list is open, so I imagine its to refresh the labels right?
