I have used the online font converter successfully in the past. But I just received an update to one of the font files which includes two new codepoints: E0020 and E0021. I am now getting an error trying to convert the font. The error message is “Codepoint delta out of range”
I am trying to convert symbols from two font files into one .c file.
I can convert the range from either font file independently with no error. But when I try to do both files I have no success.
My first font file is is a DroidSans_Mono.ttf file which has been modified to add the two codepoints listed above (E0020, E0021). The range that I provide to the converter is:
0xE0020-0xE0021,0x20-0x7F,0xA0-0xFF
The second font file is FontAwesome5-Solid+Brands+Regular.woff. The range for this font is:
0xf00c,0xf00d,0xf55a,0xf8a2
If I convert only the DroidSans_Mono.ttf file with the range listed above it converts without error
If I convert only the FontAwesome file with the range listed above it converts without error
If I try to combine both fonts but remove the range 0xE0020-0xE0021 it converts without error
Only when I combine both font files and include the range 0xE0020-0xE0021 do I get the codepoint delta error.
Is this an error in the font converter or am I doing something incorrect?
