flush_cb not being executed
STM32F746DISC, makefile, Notepad++, gcc
Create driver for Discovery board
I created the driver using https://github.com/Shadofisher/STM32F746_LittleVGL as a base. The examples were used to wrap the code in Micropython. Compile is good and functions visible in Micropython. Init() executes without any problem but the flush_cb is never executed. I tried both registering the driver in C and Micropython but the same result. There is a LED on board that I use to see the activity, but there is no change in LED status. Anybody who have done the driver for 746DISC board?
and ```
tags:
#define LAYER0_ADDRESS (0xc0000000)
static uint32_t * my_fb = (uint32_t *)LAYER0_ADDRESS;
void CopyBuffer(const uint32_t *pSrc, uint32_t *pDst, uint16_t x, uint16_t y, uint16_t xsize, uint16_t ysize)
HAL_GPIO_WritePin(GPIOI, GPIO_PIN_1, GPIO_PIN_SET); /* LED ON */
uint32_t row;
for(row = y; row < y + ysize; row++ ) {
memcpy(&pDst[row * 480 + x], pSrc, xsize * 2);
pSrc += xsize;
HAL_GPIO_WritePin(GPIOI, GPIO_PIN_1, GPIO_PIN_RESET); /* LED OFF */
CopyBuffer((const uint32_t *)color_p, my_fb, area->x1, area->y1, lv_area_get_width(area), lv_area_get_height(area));
/* IMPORTANT!!!
STATIC mp_obj_t init(void) {
//static lv_disp_buf_t disp_buf;
//static lv_color_t buf_1[LV_HOR_RES_MAX * LV_VER_RES_MAX]; /*A screen sized buffer*/
//static lv_color_t buf_2[LV_HOR_RES_MAX * LV_VER_RES_MAX]; /*An other screen sized buffer*/
//lv_disp_buf_init(&disp_buf, buf_1, NULL, LV_HOR_RES_MAX * LV_VER_RES_MAX); /*Initialize the display buffer*/
//lv_disp_buf_init(&disp_buf, (lv_color_t *)0xC0000000, (lv_color_t *)0xC0050000, 130560);
//lv_disp_drv_t disp_drv; /*Descriptor of a display driver*/
//lv_disp_drv_init(&disp_drv); /*Basic initialization*/
//disp_drv.hor_res = 480;
//disp_drv.ver_res = 272;
//disp_drv.flush_cb = disp_flush;
/*Set a display buffer*/
//disp_drv.buffer = &disp_buf;
//lv_disp_drv_register(&disp_drv);
disp_init(); /* This part set the LTDC and DMA2D peripherals */
return mp_const_none;
// Define a Python reference to the function above
STATIC MP_DEFINE_CONST_FUN_OBJ_1(init_obj, init);
DEFINE_PTR_OBJ(disp_flush);
// Define all properties of the example module.
// Table entries are key/value pairs of the attribute name (a string)
// and the MicroPython object reference.
// All identifiers and strings are written as MP_QSTR_xxx and will be
// optimized to word-sized integers by the build system (interned strings).
STATIC const mp_rom_map_elem_t ltdc_globals_table[] = {
{ MP_ROM_QSTR(MP_QSTR___name__), MP_ROM_QSTR(MP_QSTR_ltdc) },
{ MP_ROM_QSTR(MP_QSTR_init), MP_ROM_PTR(&init_obj) },
{ MP_ROM_QSTR(MP_QSTR_disp_flush), MP_ROM_PTR(&PTR_OBJ(disp_flush))},
STATIC MP_DEFINE_CONST_DICT(ltdc_module_globals, ltdc_globals_table);
// Define module object.
const mp_obj_module_t ltdc_cmodule = {
.base = { &mp_type_module },
.globals = (mp_obj_dict_t*)<dc_module_globals,
// Register the module to make it available in Python
MP_REGISTER_MODULE(MP_QSTR_ltdc, ltdc_cmodule, MODULE_LTDC_ENABLED);
// For the Micropython code :
import lvgl as lv
import ltdc
import lvstm32
lv.init()
ltdc.init()
disp_buf1 = lv.disp_buf_t()
buf1_1 = bytearray(480*272)
lv.disp_buf_init(disp_buf1,buf1_1, None, len(buf1_1)//4)
disp_drv = lv.disp_drv_t()
lv.disp_drv_init(disp_drv)
disp_drv.buffer = disp_buf1
disp_drv.flush_cb = ltdc.disp_flush
lv.disp_drv_register(disp_drv)
scr = lv.obj()
btn = lv.btn(scr)
btn.align(lv.scr_act(), lv.ALIGN.CENTER, 0, 0)
label = lv.label(btn)
label.set_text("Hello World!")
lv.scr_load(scr)
