when i porting LVGL to my project,i test with example code,but Flush_cb() can’t be called.
THM3682FAQD
V7.10.0
i just want to test LVGL and display “hello word” on LCD screen.
i tried sample code on lvgl website
void task()
hal_init();
lv_demo();
while()
lv_task_handler();
lv_tick_inc(10);
sleep(100);
static void hal_init()
//disp_init();
lv_disp_buf_t draw_buf_dsc_1; /*A buffer for 10 rows*/
lv_color_t draw_buf_1[1024];
lv_disp_buf_init(&draw_buf_dsc_1, draw_buf_1, NULL, 1024); /*Initialize the display buffer*/
lv_disp_drv_t disp_drv; /*Descriptor of a display driver*/
disp_drv.hor_res = LV_HOR_RES_MAX;
disp_drv.ver_res = LV_VER_RES_MAX;
disp_drv.flush_cb = Flush_cb;
/*Set a display buffer*/
disp_drv.buffer = &draw_buf_dsc_1;
#if LV_USE_GPU
/Optionally add functions to access the GPU. (Only in buffered mode, LV_VDB_SIZE != 0)/
/*Blend two color array using opacity*/
disp_drv.gpu_blend_cb = gpu_blend;
/*Fill a memory array with a color*/
disp_drv.gpu_fill_cb = gpu_fill;
volatile u8 *FrameBuffer = (u8 *)0x2003C000;
static void Flush_cb(lv_disp_drv_t * disp_drv, const lv_area_t * area, lv_color_t * color_p)
u32 y;
u32 x;
for(y = area->y1; y <= area->y2 && y <disp_drv->ver_res; y++)
for(x = area->x1; x <= area->x2; x++)
//pDisp[y *disp_drv->hor_res + x] = (u32)lv_color_to32(*color_p);
FrameBuffer[y *disp_drv->hor_res + x] = (u32)lv_color_to32(*color_p);
color_p++;
lark_lcd_write(LCD_NORMAL,area->x1, area->y1, x, y, FrameBuffer);//my lcd driver function
static void lv_demo()
lv_obj_t * scr = lv_disp_get_scr_act(NULL);
lv_obj_t * label1 = lv_label_create(scr, NULL);
lv_label_set_text(label1, “Hello\nworld”);
lv_obj_align(label1, NULL, LV_ALIGN_CENTER, 0, 0);
