Flush callback Problem
Hello everyone,
I used LVGL for my application. After porting my device, my screen showed as the figure below. Can any body know what happen?
Stm32L476RG and ST7565 - my screen
V7-10
    /*The most simple case (but also the slowest) to put all pixels to the screen one-by-one*/
//	LREP("\r\n(%d,%d) (%d,%d)",(long)(area->x1), (long)(area->y1), (long)(area->x2), (long)(area->y2));
    /* IMPORTANT!!!
//	LcdFillRect(area->x1, area->y1, abs(area->x2 - area->x1 +1) , abs(area->y2 - area->y1), color_p->full);
    if(area->x2 < 0) return;
    if(area->y2 < 0) return;
    if(area->x1 > 128 - 1) return;
    if(area->y1 > 64 - 1) return;
    int32_t act_x2 = area->x2 > (128 - 1) ? (128 - 1) : area->x2;
    int32_t act_y2 = area->y2 > (64 - 1) ? (64 - 1) : area->y2;
    int32_t x, y;
    /*Refresh frame buffer*/
    for(y = act_y1; y <= act_y2; y++) {
        for(x = act_x1; x <= act_x2; x++) {
            if(lv_color_to1(*color_p) != 0) {
            	st7565_buffer[x + (y / 8)*128] &= ~(1 << ((y % 8)));
            } else {
            	st7565_buffer[x + (y / 8)*64] |= (1 << ((y % 8)));
            color_p ++;
        color_p += area->x2 - act_x2; //Next row
	LcdSetBufferPixel(st7565_buffer);
My main function:
int main(void)
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_USART2_UART_Init();
  MX_USB_DEVICE_Init();
  /* USER CODE BEGIN 2 */
  LREP("\r\n[LVGL Build Date:<%s>.<%s>]\r\n",BUILD_TIME,BUILD_DATE);
  //TestDisplay();
  memset(st7565_buffer,0,1024);
#if(1)
  lv_port_disp_init();
  //lv_theme_t * th = lv_theme_mono_init(LV_COLOR_BLACK, LV_COLOR_BLACK, LV_THEME_MATERIAL_FLAG_DARK, LV_FONT_MONTSERRAT_12,LV_FONT_MONTSERRAT_12,LV_FONT_MONTSERRAT_12,LV_FONT_MONTSERRAT_12);
  //lv_obj_t * scr = lv_disp_get_scr_act(NULL);
  //lv_theme_set_act(th); // Not run USB CDC
  // Input device keyboard
//  lv_indev_drv_t indev_drv;
//  lv_indev_drv_init(&indev_drv);      /*Basic initialization*/
//  indev_drv.read_cb = button_read;
//  /*Register the driver in LVGL and save the created input device object*/
//  lv_indev_t * my_indev = lv_indev_drv_register(&indev_drv);
  lv_theme_t * th = lv_theme_mono_init(LV_COLOR_BLACK, LV_COLOR_BLACK, 0, &lv_font_montserrat_12, &lv_font_montserrat_12,
		  &lv_font_montserrat_12, &lv_font_montserrat_12);
  /* Set the mono system theme */
#if(1)
  /*Create a Label on the currently active screen*/
//  lv_style_init(&my_style);
//  lv_style_set_text_font(&my_style,LV_STATE_DEFAULT,LV_THEME_DEFAULT_FONT_SMALL);
  label1 =  lv_label_create(scr, NULL);
//  lv_obj_set_pos(label1,3, 3);    // position, position);
  lv_obj_align(label1, NULL, LV_ALIGN_CENTER, 0, 0);
  lv_label_set_text(label1, "abc123");
  LREP("\r\n[LVGL Object]\r\n");
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
	 lv_tick_inc(1);
	 lv_task_handler();
	 HAL_Delay(10);
I’m looking forward to seeing your reply.
Thanks,
Best Regards,
You use a different index calculation.
For != 0 you use *128
and for else you use *64
            } else {
OMG thanks. I found my issue.Such a silly issue. by the way, Does it necessary to add rounder function and set px functions???
set_px_cb should be avoided unless absolutely necessary as it introduces a huge penalty to rendering speed.
rounder_cb is generally only necessary if your driver requires areas to be a multiple of a certain size.
okay tks. I got it!!
