Hello, I’ve got an issues where my widgets are flickering like in the attached video.
STM32H743IIT6 + SDRAM + LTDC Screen (custom board) with ChibiOS and GCC
Current master (9.3)
Remove the flickering
Using direct render mode and double buffering, additionally ported all RTOS functions to ChibiOS
uint8_t frame_buffer[600 * 1024 * 2] __attribute__((section(".sdram"), aligned(32)));
uint8_t frame_buffer_optional[600 * 1024 * 2] __attribute__((section(".sdram"), aligned(32)));
uint8_t view_buffer[600 * 1024 * 2] __attribute__((section(".sdram"), aligned(32)));
static THD_WORKING_AREA(waLV_TIMER_HANDLER, 4096);
static THD_FUNCTION(LV_TIMER_HANDLER, arg)
(void)arg;
chRegSetThreadName("LV_TIMER_HANDLER");
uint32_t sleep = 0;
while (true)
sleep = lv_timer_handler();
if (sleep == LV_NO_TIMER_READY)
sleep = LV_DEF_REFR_PERIOD;
if (sleep <= 0)
sleep = 1;
chThdSleepMilliseconds(sleep);
static THD_WORKING_AREA(waLV_TICK, 2048);
static THD_FUNCTION(LV_TICK, arg)
(void)arg;
chRegSetThreadName("LV_TICK_HANDLER");
while (true)
lv_tick_inc(10);
chThdSleepMilliseconds(10);
static THD_WORKING_AREA(waLV_GFX, 4096);
static THD_FUNCTION(LV_GFX, arg)
(void)arg;
chRegSetThreadName("LV_GFX_HANDLER");
lv_lock();
ui_init();
lv_unlock();
float test = 0;
bool n = false;
while (true)
lv_lock();
for (int i = 0; i < 8; i++)
update_values(test, 0, i);
if(!n)
test += 0.5f;
else if (n)
test -= 0.5f;
if (test >= 100)
n = true;
else if (test <= 0)
n = false;
lv_unlock();
void startLVGL()
palSetPad(GPIOH, 6U);
ltdcInit();
ltdcStart(<DCD1, <dc_cfg);
dma2dInit();
dma2dStart(&DMA2DD1, &dma2d_cfg);
lv_display_t *disp = lv_st_ltdc_create_direct(view_buffer, frame_buffer_optional, 0);
chThdCreateStatic(waLV_TIMER_HANDLER, sizeof(waLV_TIMER_HANDLER), NORMALPRIO, LV_TIMER_HANDLER, NULL);
chThdCreateStatic(waLV_TICK, sizeof(waLV_TICK), NORMALPRIO, LV_TICK, NULL);
chThdCreateStatic(waLV_GFX, sizeof(waLV_GFX), NORMALPRIO, LV_GFX, NULL);
