Flickering / Jitter during screen change
Screen jitters / flickers while changing screens. Happens in both landscape and portrait orientations.
MaTouch ESP32-S3 Parallel TFT with Touch 7“
ESP32-S3-WROOM-1-N16R8, 16MB Flash, 8MB PSRAM
Screen Resolution: 1024*600
v8.3.11 and also tried with v9.1.0
Smooth transition between screens, animated or non animated. No preference.
  • Changing LVGL version to v9.1.0, same behavior
  • Changing orientations
  • Enabling / disabling screen change animations in SLS
  • Changing frequency to: 12000000, 14000000,16000000, 20000000
LCD Initialization:
Arduino_ESP32RGBPanel *bus = new Arduino_ESP32RGBPanel(
  GFX_NOT_DEFINED /* CS */, GFX_NOT_DEFINED /* SCK */, GFX_NOT_DEFINED /* SDA */,
  40 /* DE */, 41 /* VSYNC */, 39 /* HSYNC */, 42 /* PCLK */,
  45 /* R0 */, 48 /* R1 */, 47 /* R2 */, 21 /* R3 */, 14 /* R4 */,
  5 /* G0 */, 6 /* G1 */, 7 /* G2 */, 15 /* G3 */, 16 /* G4 */, 4 /* G5 */,
  8 /* B0 */, 3 /* B1 */, 46 /* B2 */, 9 /* B3 */, 1 /* B4 */
Arduino_RPi_DPI_RGBPanel *gfx = new Arduino_RPi_DPI_RGBPanel(
  bus,
  SCREEN_W /* width */, 1 /* hsync_polarity */, 40 /* hsync_front_porch */, 48 /* hsync_pulse_width */, 128 /* hsync_back_porch */,
  SCREEN_H /* height */, 1 /* vsync_polarity */, 13 /* vsync_front_porch */, 3 /* vsync_pulse_width */, 45 /* vsync_back_porch */,
  1 /* pclk_active_neg */, 14000000 /* prefer_speed */, true /* auto_flush */);
/* Display flushing */
void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p) {
#if (LV_COLOR_16_SWAP != 0)
  gfx->draw16bitBeRGBBitmap(area->x1, area->y1, (uint16_t *)&color_p->full, w, h);
#else
  gfx->draw16bitRGBBitmap(area->x1, area->y1, (uint16_t *)&color_p->full, w, h);
  lv_disp_flush_ready(disp);
setup() and loop()
void setup() {
  pinMode(TFT_BL, OUTPUT);
  digitalWrite(TFT_BL, LOW);
  delay(100);
  LVGL_Arduino += String('V') + lv_version_major() + "." + lv_version_minor() + "." + lv_version_patch();
  Serial.println(LVGL_Arduino);
  Serial.println("I am LVGL_Arduino");
  pin_init();
  touch_init(gfx->width(), gfx->height());
  // Init Display
  gfx->begin();
#if LV_USE_LOG != 0
  lv_log_register_print_cb(my_print); /* register print function for debugging */
#ifdef ESP32
  disp_draw_buf = (lv_color_t *)heap_caps_malloc(sizeof(lv_color_t) * screenWidth * 10, MALLOC_CAP_INTERNAL | MALLOC_CAP_8BIT);
#else
  disp_draw_buf = (lv_color_t *)malloc(sizeof(lv_color_t) * screenWidth * 10);
  if (!disp_draw_buf) {
    Serial.println("LVGL disp_draw_buf allocate failed!");
  } else {
    lv_disp_draw_buf_init(&draw_buf, disp_draw_buf, NULL, screenWidth * 10);
    /*Initialize the display*/
    lv_disp_drv_init(&disp_drv);
    disp_drv.sw_rotate = 1;
    disp_drv.rotated = LV_DISP_ROT_90;
    disp_drv.full_refresh = 1;
    /*Initialize the touch input driver*/
    ui_init();
  Serial.println("Setup done");
void loop() {
  delay(5);
Video: https://youtube.com/shorts/QutcEuve9I0?feature=share
Hi I have the same probleem:
  • ESP32S3-WROOM-2-N32R8, 32MB Flash, 8MB PSRAM
  • LCD display, 480x480 px, 16bit RGB interface. I am using LVGL 8.3.4
  • Using ESP-IDF 5.2.1
  • Changing the PCLK frequency from 16000000, to 8000000, to 10000000
in my main.c
lvgl_mux = xSemaphoreCreateRecursiveMutex();
xTaskCreatePinnedToCore(lvgl_port_task, "LVGL", LVGL_STACK_SIZE, NULL, 15, NULL, 1 );
// Tick interface for LVGL
const esp_timer_create_args_t lvgl_tick_timer_args =
    .callback = increase_lvgl_tick,
    .name = "lvgl_tick"
esp_timer_handle_t lvgl_tick_timer;
esp_timer_create(&lvgl_tick_timer_args, &lvgl_tick_timer);
esp_timer_start_periodic(lvgl_tick_timer, portTICK_PERIOD_MS * 1000);
if (lvgl_lock(-1))
    ui_init();
    lvgl_unlock();
backlight_init( LCD_PIN_BK_LIGHT );
This is my initialization code for the display:
void qmsd_rgb_spi_init()
spi_bus_config_t buscfg = {
.sclk_io_num = LCD_SPI_CLK,
.mosi_io_num = LCD_SPI_DATA0,
.miso_io_num = -1,
.quadwp_io_num = -1,
.quadhd_io_num = -1,
.max_transfer_sz = 10 * 1024,
ESP_ERROR_CHECK(spi_bus_initialize(SPI2_HOST, &buscfg, SPI_DMA_CH_AUTO));
spi_device_interface_config_t devcfg = {
    .clock_speed_hz = 10 * 1000 * 1000,     //Clock out at 10 MHz
    .mode = 0,                              //SPI mode 0
    .spics_io_num = LCD_SPI_CS,             //CS pin
    .queue_size = 7,                        //We want to be able to queue 7 transactions at a time
ESP_ERROR_CHECK(spi_bus_add_device(SPI2_HOST, &devcfg, &g_screen_spi));
rgb_driver_init();
gpio_set_drive_capability( (gpio_num_t)LCD_PCLK_GPIO, GPIO_DRIVE_CAP_0 );       // Strongest setting, or blurry edges
spi_bus_remove_device(g_screen_spi);
spi_bus_free(SPI2_HOST);
gpio_config_t io_conf =
    .intr_type = GPIO_INTR_DISABLE,
    .pin_bit_mask = BIT64(LCD_SPI_CS),
    .mode = GPIO_MODE_OUTPUT
gpio_config(&io_conf);
gpio_set_level( LCD_SPI_CS, 1 );
void screen_setup(void)
qmsd_rgb_spi_init();
esp_lcd_rgb_panel_config_t panel_config = {
    .data_width = 16,
    .psram_trans_align = 64,
    .pclk_gpio_num = LCD_PCLK_GPIO,
    .vsync_gpio_num = LCD_VSYNC_GPIO,
    .hsync_gpio_num = LCD_HSYNC_GPIO,
    .de_gpio_num = LCD_DE_GPIO,
    .disp_gpio_num = LCD_DISP_EN_GPIO,
    .data_gpio_nums = {
        LCD_DATA0_GPIO,
        LCD_DATA1_GPIO,
        LCD_DATA2_GPIO,
        LCD_DATA3_GPIO,
        LCD_DATA4_GPIO,
        LCD_DATA5_GPIO,
        LCD_DATA6_GPIO,
        LCD_DATA7_GPIO,
        LCD_DATA8_GPIO,
        LCD_DATA9_GPIO,
        LCD_DATA10_GPIO,
        LCD_DATA11_GPIO,
        LCD_DATA12_GPIO,
        LCD_DATA13_GPIO,
        LCD_DATA14_GPIO,
        LCD_DATA15_GPIO,
    .timings = {
        .pclk_hz = 16 * 1000 * 1000,
        .h_res = 480,
        .v_res = 480,
        .hsync_pulse_width = 8,
        .hsync_back_porch = 13,
        .hsync_front_porch = 10,
        .vsync_pulse_width = 8,
        .vsync_back_porch = 13,
        .vsync_front_porch = 2,
    .flags.fb_in_psram = 1,
    .flags.refresh_on_demand = 0,   // Mannually control refresh operation
    .flags.double_fb = 1,
    // .bounce_buffer_size_px = 4800,
    .clk_src = LCD_CLK_SRC_PLL160M,
qmsd_rgb_init(&panel_config);
This is the link to the video showing the issue:
Kind regards.
