I have a container with two containers A and B in it. I want both A and B containers to fir the width of the parent container. Then I want A to be as high as its children need it and B to fill the left over vertical space.
I don’t see right now how to do it and it might not be possible but I wanted to ask before hard coding B’s height.
Filling the rest of the space of a parent when there are already other elements in it is a
I don’t think that matters for this question.
I try to have a container fill the left over space of a parent container when there are other containers in the same container already.
I tried to use lv_cont_set_fit2 but it yields an error. It works if container A is not created but if I have A and then I fit B it yields an error. I read the documentation and I was a bit optimistic by using it but I don’t see any other function or object that could help me with that.
lv_obj_t* container = lv_cont_create(scr, NULL);
lv_cont_set_layout(container, LV_LAYOUT_COL_L); /* set the layout to columns*/
lv_obj_set_size(container, WIDTH, HEIGHT); /*Set the size of the parent container*/
lv_obj_t* top_container = lv_cont_create(container, NULL);
lv_obj_t* list = lv_page_create(container, NULL);
lv_cont_set_fit2(list, LV_FIT_FLOOD, LV_FIT_FLOOD); /* When I comment this line I get no errors*/
