Simulator, GCC.
v7.1.0
I’d like to be able to apply styles in a theme (that I create) in a more fine-grained way to basic widgets.
For example, if I have a label that’s a heading, I’d like to say mylabel = lv_label_create(...), “tag” it somehow, and have the theme apply a style that’s appropriate (eg. larger font, different colour).
Another application is alternating colours on table rows. Instead of having a loop that manually sets a specific colour, I could have the loop tag each row “odd” and “even”, and the theme applies the relevant background colour.
I’ve defined an enum type that uses the typical bit-as-flag idiom. Each bit is a tag eg. 0x01 means odd table row. Kind of like:
typedef enum
MY_THEME_TAG_EVEN = 1U << 0,
MY_THEME_TAG_ODD = 1U << 1,
MY_THEME_TAG_HEADER = 1U << 2
} my_theme_tag_t;
In lv_conf.h I’ve set the type for user_data on the base object to be this type ie.
typedef my_theme_tag_t lv_obj_user_data_t;
I apply the tag after creating the object eg.
myobj = lv_(whatever)_create(...);
myobj.user_data = MY_THEME_TAG_HEADER;
In my custom theme, I have the theme_apply() function read these tags and apply some extra logic eg.
void theme_apply(lv_obj_t * obj, lv_theme_style_t name)
lv_style_list_t * list;
const my_theme_tag_t tags = obj->user_data;
switch(name) {
case LV_THEME_LABEL:
lv_obj_clean_style_list(obj, LV_LABEL_PART_MAIN);
list = lv_obj_get_style_list(obj, LV_LABEL_PART_MAIN);
if (tags & MY_THEME_TAG_HEADER)
_lv_style_list_add_style(list, &styles->header);
_lv_style_list_add_style(list, &styles->bg);
break;
But since the theme is applied to the object in the create function (actually in the init function), I need to apply the theme again after tagging it, so finally:
lv_theme_apply(myobj, LV_THEME_WHATEVER);
This seems a bit clunky, and not very performant. Each style for each widget has to be applied twice, sometimes in a loop (in the case of table rows). It’s also an extra line of code for each object, which I need to remember and someone else needs to read.
But I can’t really think of a better way to do this (without modifying LVGL in my own project, which I don’t want to do). The next best thing I can think of is to ignore themes and just put all my custom styles on each object manually, which seems worse.
I didn’t want to dump my entire theme source etc. etc. in here, so I just put snippets up there. Let me know if you want more info.
