I’ve been reading the docs but I can’t get my head around what program/library files to put on my ESP32 and where to put them.
I’m running a Pycom ESP32 which is already set up and is receiving data from other boards.
I have an ili9341 screen to display the data.
I have my main.py, boot.py, lv_conf.h files and lib folder already in the root of the device.
I’ve set up a display using Edgeline and have exported some python code named Testboard.py. (I don’t know what to do with this)
I have read I also need a gen_mpy.py file (I don’t understand where to put this or where to call this from) and a driver file. Anything else?
Can someone point me in the right direction where to go from here?
Thanks very much.
I was way off base with how to use lvgl. (probably still am)
If I create a setup in Edgeline and export a python code, does that mean I don’t need to worry about the gen_mpy.py and the lv_conf.h?
If this is the case, do I rename the exported python file to lv_micropython?
To run LVGL with Micropython you need special firmware.
Please build lv_micropython and flash it to your device.
Then you could use the Python files generated by Edgeline on your device.
Note that latest lv_micropython is aligned with LVGL v8 but Edgeline only supports v7 (as far as I know).
So you would either need to modify your Python files to match v8, or sync to release/v7 of lv_micropython.
