/home/bmp/lv_micropython/extmod/modbtree.c:37:10: fatal error: db.h: No such file or directory
#include <db.h>
compilation terminated.
File “/home/bmp/lv_micropython/py/makeqstrdefs.py”, line 188, in
preprocess()
File “/home/bmp/lv_micropython/py/makeqstrdefs.py”, line 62, in preprocess
for output in p.imap(pp(flags), chunks):
File “/usr/lib/python3.8/multiprocessing/pool.py”, line 868, in next
raise value
File “/usr/lib/python3.8/multiprocessing/pool.py”, line 125, in worker
result = (True, func(*args, **kwds))
File “/home/bmp/lv_micropython/py/makeqstrdefs.py”, line 46, in run
return subprocess.check_output(args.pp + flags + files)
File “/usr/lib/python3.8/subprocess.py”, line 415, in check_output
returworks fine with micropython (without lv_bindings)n run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File “/usr/lib/python3.8/subprocess.py”, line 516, in run
it works fine with micropython。
OS: ubuntu 20.04 LTS (WSL)
idf: v4.2
looking forward to your reply,thanks.
