I’m extending the default theme based on the example provided on docs. While applying my new style to the buttons, I’ve noticed this light blue outline around it. I’ve tried setting outline to zero, but the outline still being shown.
lv_port_eclipse running on Clion
8.3
Get rid of the light blue outline around my button
lv_style_set_outline_width(&style_btn, 0);
#include "ui_lvgl.h"
static lv_style_t style_btn;
static void new_theme_apply_cb(lv_theme_t * th, lv_obj_t * obj)
LV_UNUSED(th);
if(lv_obj_check_type(obj, &lv_btn_class)) {
lv_obj_add_style(obj, &style_btn, 0);
static void theme_md_dark(void)
lv_style_init(&style_btn);
lv_style_set_bg_color(&style_btn, lv_color_hex(0x14816A));
lv_style_set_radius(&style_btn, 0);
lv_style_set_border_color(&style_btn, lv_color_hex(0x5FE2C0));
lv_style_set_border_opa(&style_btn, 150);
lv_style_set_border_width(&style_btn, 1);
lv_style_set_shadow_color(&style_btn, lv_color_hex(0x181D1B));
lv_style_set_shadow_opa(&style_btn, 150);
lv_style_set_shadow_width(&style_btn, 3);
lv_style_set_shadow_spread(&style_btn, 1);
lv_style_set_shadow_ofs_x(&style_btn, 1);
lv_style_set_shadow_ofs_y(&style_btn, 1);
lv_style_set_text_color(&style_btn, lv_color_hex(0x5FE2C0));
lv_theme_t * th_active = lv_disp_get_theme(NULL);
static lv_theme_t th_md_dark;
th_md_dark = *th_active;
lv_theme_set_parent(&th_md_dark, th_active);
lv_theme_set_apply_cb(&th_md_dark, new_theme_apply_cb);
lv_disp_set_theme(NULL, &th_md_dark);
void ui_init(void)
lv_obj_t * btn;
lv_obj_t * label;
lv_theme_default_init(NULL, lv_palette_main(LV_PALETTE_BLUE), lv_palette_main(LV_PALETTE_RED), true,
LV_FONT_DEFAULT);
theme_md_dark();
btn = lv_btn_create(lv_scr_act());
lv_obj_align(btn, LV_ALIGN_TOP_MID, 0, 20);
label = lv_label_create(btn);
lv_label_set_text(label, "PERF");
