Event input normalisation
I have a number of touch screens, 7 and 10 inch versions.
Some of the 7 inch screens use 0 > 2000 as the touch areas whereas the 10 inch one and a 7 inch one has a 0 > 4000 touch area.
Instead of having to alter the lv_drv_conf.h file for each is there a way to normalise them to 0>2000?
I know I might be asking the question in the wrong place but I was hoping someone here might be able to answer the question.
Maybe I’m going about it the wrong way?
Raspberry Pi Zero/Zero2
8.1
As described
Altering the driver config for each screen
#  define EVDEV_CALIBRATE         1               /*Scale and offset the touchscreen coordinates by using maximum and minimum values for each axis*/
#  if EVDEV_CALIBRATE
#    define EVDEV_HOR_MIN         20               /*to invert axis swap EVDEV_XXX_MIN by EVDEV_XXX_MAX*/
#    define EVDEV_HOR_MAX      4000               /*"evtest" Linux tool can help to get the correct calibraion values>*/
#    define EVDEV_VER_MIN         20
#    define EVDEV_VER_MAX      4000
#  endif  /*EVDEV_CALIBRATE*/
#endif  /*USE_EVDEV*/
and
#    define EVDEV_HOR_MAX      2000               /*"evtest" Linux tool can help to get the correct calibraion values>*/
#    define EVDEV_VER_MAX      2000
N/A
