I’m in the classic situation where i set a callback function to a button with:
lv_obj_set_event_cb(btn_tmp, ssid_selected);
and the function:
void ssid_selected(lv_obj_t * obj, lv_event_t event){
/* My code */
But now i whant to insert an extra argument to the function, such as:
lv_obj_set_event_cb(btn_tmp, ssid_selected(string));
and
void ssid_selected(lv_obj_t * obj, lv_event_t event, char *string){
/* My code */
How can i do this?
ESP32 on Arduino Toolchain.
An action function with an extra argument to my button.
The code above mentioned.
See:
uint8_t protect; /**< Automatically happening actions can be prevented. 'OR'ed values from
`lv_protect_t`*/
lv_opa_t opa_scale; /**< Scale down the opacity by this factor. Effects all children as well*/
lv_coord_t ext_draw_pad; /**< EXTtend the size in every direction for drawing. */
#if LV_USE_OBJ_REALIGN
lv_reailgn_t realign; /**< Information about the last call to ::lv_obj_align. */
#if LV_USE_USER_DATA
lv_obj_user_data_t user_data; /**< Custom user data for object. */
} lv_obj_t;
/*Protect some attributes (max. 8 bit)*/
enum {
LV_PROTECT_NONE = 0x00,
LV_PROTECT_CHILD_CHG = 0x01, /**< Disable the child change signal. Used by the library*/
LV_PROTECT_PARENT = 0x02, /**< Prevent automatic parent change (e.g. in lv_page)*/
and:
void * lv_obj_get_ext_attr(const lv_obj_t * obj);
* Get object's and its ancestors type. Put their name in `type_buf` starting with the current type.
* E.g. buf.type[0]="lv_btn", buf.type[1]="lv_cont", buf.type[2]="lv_obj"
* @param obj pointer to an object which type should be get
* @param buf pointer to an `lv_obj_type_t` buffer to store the types
void lv_obj_get_type(const lv_obj_t * obj, lv_obj_type_t * buf);
* Get the object's user data
* @return user data
lv_obj_user_data_t lv_obj_get_user_data(const lv_obj_t * obj);
* Get a pointer to the object's user data
Thanks, i will give a try.
Ok, i’m using lv_obj_set_user_data and lv_obj_get_user_data. But now the problem is that the object is a local variable, so i can’t call it in the callback function. I show you why.
I need to create a button list of available wifi networks around me, so i used the following commands:
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay_ms(10);
int n = WiFi.scanNetworks();
if (n == 0) {
} else{
String ssid[n];
String rssi[n];
for (int i = 0; i < n; ++i) {
ssid[i] = WiFi.SSID(i);
rssi[i] = WiFi.RSSI(i);
delay_ms(10);
wifi_lst = lv_list_create(lv_scr_act(), NULL);
lv_obj_set_size(wifi_lst, 300, 180);
lv_obj_align(wifi_lst, NULL, LV_ALIGN_CENTER, 0, 0);
uint8_t ssid_buf_len = 80;
uint8_t str_buf_len = 100;
for(int i = 0; i<n; i++) {
char ssid_char[ssid_buf_len];
char str_char[str_buf_len];
(ssid[i] + " (" + rssi[i] + " dB)").toCharArray(str_char, str_buf_len);
lv_obj_t *btn_tmp = lv_list_add_btn(wifi_lst, LV_SYMBOL_WIFI, str_char);
lv_obj_set_user_data(btn_tmp,ssid_char);
But, obviously, the callback function can’t call the object btn_tmp. How can i do this?
The object that’s passed to the event callback is btn_tmp.
You are right. But how can i use lv_obj_get_user_data? I’m trying something like:
void ssid_selected(lv_obj_t *obj, lv_event_t event){
if(event == LV_EVENT_SHORT_CLICKED){
Serial.println((char*)lv_obj_get_user_data(obj));
lv_btn_set_state(wifi_btn, LV_BTN_STATE_TGL_REL);
lv_obj_del(wifi_lst);
wifi_icon_update();
But it returns nosense strings.
ssid_char is a local variable, so it loses its value outside of that for loop. You’ll need to allocate a buffer to store that string in and then call lv_obj_set_user_data with the pointer to that buffer.
Perfect, it works! Thank you,
Alberto.
One moment. I noticed it return always the last button! How can i solve it?
I wonder what is the sense of using lv_obj_get_user_data with a global variable, if i can take that variable directly.
If you have a global variable, you can use that variable directly. In this case, the value of ssid_char is specific to each button, so you would want to use user_data for that.
What returns the last button? lv_list_add_btn returns a pointer to whatever button it created.
I mean the following.
I have three networks around me. When i create the list with
ssid[i].toCharArray(ssid_char,ssid_buf_len);
I can see all three networks ordered by signal quality (we call them WiFi1, WiFi2 and WiFi3).
I used global variables, as you suggested:
// Variables for wifi networks list
const uint8_t ssid_buf_len = 80;
const uint8_t str_buf_len = 100;
My callback function is
upper_bar_update();
But whichever connection I choose it prints always the last one.
I didn’t suggest using a global variable. I suggested allocating a buffer (e.g. using malloc or lv_mem_alloc) for each string. When you use a global variable it will also get overriden each time the for loop runs.
I never used it. How can i implement malloc in my code? When can i use free to deallocate memory?
You can free the memory when the button is deleted (LV_EVENT_DELETE should work for this purpose).
if(event == LV_EVENT_DELETE){
free(lv_obj_get_user_data(obj));
