I want to place events for animation and arc value change.
Simulator Code Blocks
V8
Change screen in animation finish time.
static void set_angle(void * obj, int32_t v)
    lv_arc_set_value(obj, v);
static void arc_event_cb(lv_event_t * e)
    if (code == LV_EVENT_READY)
       CreateScreenMain();
static void button_event_cb(lv_event_t * e)
    if(code == LV_EVENT_CLICKED)
        CreateScreenMain();
lv_obj_t* CreateScreenLoading(void)
    lv_obj_t *Screenloading = lv_obj_create(NULL);
    lv_scr_load(Screenloading);
    lv_obj_t * btn = lv_btn_create(Screenloading);
    lv_obj_set_size(btn, 100, 50);
    lv_obj_center(btn);
    lv_obj_add_event_cb(btn, button_event_cb, LV_EVENT_CLICKED, NULL);
    lv_obj_t * label = lv_label_create(btn);
    lv_label_set_text(label, "Load Page");
    lv_obj_center(label);
    lv_obj_t * arc = lv_arc_create(Screenloading);
    lv_arc_set_rotation(arc, 270);
    lv_arc_set_bg_angles(arc, 0, 360);
    lv_obj_remove_style(arc, NULL, LV_PART_KNOB);
    lv_obj_clear_flag(arc, LV_OBJ_FLAG_CLICKABLE);
    lv_obj_center(arc);
    lv_obj_set_size(arc,400,400);
    lv_anim_t a;
    lv_anim_init(&a);
    lv_anim_set_var(&a, arc);
    lv_anim_set_exec_cb(&a, set_angle);
    lv_anim_set_time(&a, 1000);
    lv_anim_start(&a);
    lv_obj_add_event_cb(&a,arc_event_cb,LV_EVENT_ALL,NULL);
    return Screenloading;
The event for the button is working, but the other event doesn’t. Where is the problem?
