Once 180° display rotation is enabled (fbdev device), the touchscreen (evdev device) is not working correctly and the coordinates seems swapped/wrong.
After rotation the library notify me with LOG messages that indicates the coordinates are negative.
PREMISE: The display resolution is 800x480 instead the touchscreen is a 2047x2047, so calibration is needed from my side.
Thank you in advance for the support ![]()
ARM Linux (NXP IMX6)
LVGL v.9.1
I’ve temporary workaround the problem and the device is now working (see below), but I want to notify you about the strange behaviour of the library and maybe you can guide me to the correct manner for fix my problem.
- I’ve temporary fix the problem calling differently the method lv_evdev_set_calibration(…) in case the display is rotated:
DISPLAY NOT ROTATED → lv_evdev_set_calibration(touch, 0, 0, 2047, 2047);
DISPLAY ROTATED → lv_evdev_set_calibration(touch, 2047, 2047, 0, 0);
- I’ve also modified the file lv_indev.c as follows:
if(disp->rotation == LV_DISPLAY_ROTATION_180 || disp->rotation == LV_DISPLAY_ROTATION_270) {
data->point.x = (disp->hor_res - data->point.x - 1) * -1;
data->point.y = (disp->ver_res - data->point.y - 1) * -1;
#include "generated/ui.h"
#define ROTATE_DISPLAY
int main() {
/*DISPLAY*/
lv_display_t *disp = lv_linux_fbdev_create();
lv_linux_fbdev_set_file(disp, "/dev/fb0");
lv_display_set_resolution(disp, 800, 480);
lv_display_set_physical_resolution(disp, 800, 480);
/*TOUCHSCREEN*/
lv_indev_t *touch = lv_evdev_create(LV_INDEV_TYPE_POINTER, "/dev/input/event4");
#ifdef ROTATE_DISPLAY
lv_display_set_rotation(disp, LV_DISPLAY_ROTATION_180);
#else
lv_indev_set_display(touch, disp);
ui_init();
while (true) {
lv_timer_handler();
lv_tick_inc( 10 );
