ESP32S3R8 support
I have a 4D Board and would like to run lvgl on it.
Looking for any hints in what direction I could invesigate further.
Run LGVL Demo on board the same way as here: 4D Systems gen4-ESP32-50CT - board certification review | LVGL’s Blog
n file included from /media/developer/dev1/work/st/_esp/lvgl/lv_port_esp32/components/lvgl_esp32_drivers/lvgl_helpers.h:17,
                 from /media/developer/dev1/work/st/_esp/lvgl/lv_port_esp32/components/lvgl_esp32_drivers/lvgl_helpers.c:10:
/media/developer/dev1/work/st/_esp/lvgl/lv_port_esp32/components/lvgl_esp32_drivers/lvgl_helpers.c: In function 'lvgl_driver_init':
/media/developer/dev1/work/st/_esp/lvgl/lv_port_esp32/components/lvgl_esp32_drivers/lvgl_spi_conf.h:68:22: error: 'HSPI_HOST' undeclared (first use in this function); did you mean 'SPI3_HOST'?
 #define TFT_SPI_HOST HSPI_HOST
/media/developer/dev1/work/st/_esp/lvgl/lv_port_esp32/components/lvgl_esp32_drivers/lvgl_helpers.c:111:26: note: in expansion of macro 'TFT_SPI_HOST'
     lvgl_spi_driver_init(TFT_SPI_HOST,
/media/developer/dev1/work/st/_esp/lvgl/lv_port_esp32/components/lvgl_esp32_drivers/lvgl_spi_conf.h:68:22: note: each undeclared identifier is reported only once for each function it appears in
In file included from /media/developer/dev1/work/st/_esp/lvgl/lv_port_esp32/components/lvgl_esp32_drivers/lvgl_helpers.c:11:
/media/developer/dev1/work/st/_esp/lvgl/lv_port_esp32/components/lvgl_esp32_drivers/lvgl_helpers.c: In function 'lvgl_spi_driver_init':
/media/developer/dev1/work/st/_esp/lvgl/lv_port_esp32/components/lvgl_esp32_drivers/lvgl_helpers.c:219:51: error: 'spi_names' undeclared (first use in this function); did you mean 'spi_dev_s'?
     ESP_LOGI(TAG, "Configuring SPI host %s (%d)", spi_names[host], host);
/media/developer/dev1/work/st/_esp/esp_idf/esp-idf/components/log/include/esp_log.h:421:137: note: in definition of macro 'ESP_LOG_LEVEL'
         if (level==ESP_LOG_ERROR )          { esp_log_write(ESP_LOG_ERROR,      tag, LOG_FORMAT(E, format), esp_log_timestamp(), tag, ##__VA_ARGS__); } \
/media/developer/dev1/work/st/_esp/esp_idf/esp-idf/components/log/include/esp_log.h:353:38: note: in expansion of macro 'ESP_LOG_LEVEL_LOCAL'
 #define ESP_LOGI( tag, format, ... ) ESP_LOG_LEVEL_LOCAL(ESP_LOG_INFO,    tag, format, ##__VA_ARGS__)
/media/developer/dev1/work/st/_esp/lvgl/lv_port_esp32/components/lvgl_esp32_drivers/lvgl_helpers.c:219:5: note: in expansion of macro 'ESP_LOGI'
ninja: build stopped: subcommand failed.
ninja failed with exit code 1
