ESP32S3 size buffer alignment 16
Does LVGL support creating 16-byte aligned buffers?
Because the ESP modules enable secure mode and flash encryption, the LCD buffer size requires 16-byte alignment.
/** Align stride of all layers and images to this bytes */
#define LV_DRAW_BUF_STRIDE_ALIGN 16
/** Align start address of draw_buf addresses to this bytes*/
#define LV_DRAW_BUF_ALIGN 16
lv_display_set_buffers(display, buf1, NULL, 480* 320* sizeof(lv_color_t), LV_DISPLAY_RENDER_MODE_PARTIAL);
 * @file lv_conf.h
 * Configuration file for v9.3.0
 * Copy this file as `lv_conf.h`
 * 1. simply next to `lvgl` folder
 * 2. or to any other place and
 *    - define `LV_CONF_INCLUDE_SIMPLE`;
 *    - add the path as an include path.
/* clang-format off */
#if 1 /* Enable content */
#ifndef LV_CONF_H
#define LV_CONF_H
/* If you need to include anything here, do it inside the `__ASSEMBLY__` guard */
#if  0 && defined(__ASSEMBLY__)
#include "my_include.h"
   COLOR SETTINGS
/** Color depth: 1 (I1), 8 (L8), 16 (RGB565), 24 (RGB888), 32 (XRGB8888) */
#define LV_COLOR_DEPTH 16
   STDLIB WRAPPER SETTINGS
/** Possible values
 * - LV_STDLIB_BUILTIN:     LVGL's built in implementation
 * - LV_STDLIB_CLIB:        Standard C functions, like malloc, strlen, etc
 * - LV_STDLIB_MICROPYTHON: MicroPython implementation
 * - LV_STDLIB_RTTHREAD:    RT-Thread implementation
 * - LV_STDLIB_CUSTOM:      Implement the functions externally
#define LV_USE_STDLIB_MALLOC    LV_STDLIB_BUILTIN
/** Possible values
#define LV_USE_STDLIB_STRING    LV_STDLIB_BUILTIN
/** Possible values
#define LV_USE_STDLIB_SPRINTF   LV_STDLIB_BUILTIN
#define LV_STDINT_INCLUDE       <stdint.h>
#define LV_STDDEF_INCLUDE       <stddef.h>
#define LV_STDBOOL_INCLUDE      <stdbool.h>
#define LV_INTTYPES_INCLUDE     <inttypes.h>
#define LV_LIMITS_INCLUDE       <limits.h>
#define LV_STDARG_INCLUDE       <stdarg.h>
#if LV_USE_STDLIB_MALLOC == LV_STDLIB_BUILTIN
    /** Size of memory available for `lv_malloc()` in bytes (>= 2kB) */
    #define LV_MEM_SIZE (1024 * 128)
    /** Size of the memory expand for `lv_malloc()` in bytes */
    #define LV_MEM_POOL_EXPAND_SIZE 0
    /** Set an address for the memory pool instead of allocating it as a normal array. Can be in external SRAM too. */
    #define LV_MEM_ADR 0     /**< 0: unused*/
    /* Instead of an address give a memory allocator that will be called to get a memory pool for LVGL. E.g. my_malloc */
    #if LV_MEM_ADR == 0
        #undef LV_MEM_POOL_INCLUDE
        #undef LV_MEM_POOL_ALLOC
#endif  /*LV_USE_STDLIB_MALLOC == LV_STDLIB_BUILTIN*/
   HAL SETTINGS
/** Default display refresh, input device read and animation step period. */
#define LV_DEF_REFR_PERIOD  10      /**< [ms] */
/** Default Dots Per Inch. Used to initialize default sizes such as widgets sized, style paddings.
 * (Not so important, you can adjust it to modify default sizes and spaces.) */
#define LV_DPI_DEF 130              /**< [px/inch] */
 * OPERATING SYSTEM
/** Select operating system to use. Possible options:
 * - LV_OS_NONE
 * - LV_OS_PTHREAD
 * - LV_OS_FREERTOS
 * - LV_OS_CMSIS_RTOS2
 * - LV_OS_RTTHREAD
 * - LV_OS_WINDOWS
 * - LV_OS_MQX
 * - LV_OS_SDL2
 * - LV_OS_CUSTOM */
#define LV_USE_OS   LV_OS_NONE
#if LV_USE_OS == LV_OS_CUSTOM
    #define LV_OS_CUSTOM_INCLUDE <stdint.h>
#if LV_USE_OS == LV_OS_FREERTOS
     * Unblocking an RTOS task with a direct notification is 45% faster and uses less RAM
     * than unblocking a task using an intermediary object such as a binary semaphore.
     * RTOS task notifications can only be used when there is only one task that can be the recipient of the event.
    #define LV_USE_FREERTOS_TASK_NOTIFY 1
 * RENDERING CONFIGURATION
/** Using matrix for transformations.
 * Requirements:
 * - `LV_USE_MATRIX = 1`.
 * - Rendering engine needs to support 3x3 matrix transformations. */
#define LV_DRAW_TRANSFORM_USE_MATRIX            0
/* If a widget has `style_opa < 255` (not `bg_opa`, `text_opa` etc) or not NORMAL blend mode
 * it is buffered into a "simple" layer before rendering. The widget can be buffered in smaller chunks.
 * "Transformed layers" (if `transform_angle/zoom` are set) use larger buffers
 * and can't be drawn in chunks. */
/** The target buffer size for simple layer chunks. */
#define LV_DRAW_LAYER_SIMPLE_BUF_SIZE    (32 * 1024)    /**< [bytes]*/
/* Limit the max allocated memory for simple and transformed layers.
 * It should be at least `LV_DRAW_LAYER_SIMPLE_BUF_SIZE` sized but if transformed layers are also used
 * it should be enough to store the largest widget too (width x height x 4 area).
 * Set it to 0 to have no limit. */
#define LV_DRAW_LAYER_MAX_MEMORY 0  /**< No limit by default [bytes]*/
/** Stack size of drawing thread.
 * NOTE: If FreeType or ThorVG is enabled, it is recommended to set it to 32KB or more.
#define LV_DRAW_THREAD_STACK_SIZE    (16 * 1024)         /**< [bytes]*/
/** Thread priority of the drawing task.
 *  Higher values mean higher priority.
 *  Can use values from lv_thread_prio_t enum in lv_os.h: LV_THREAD_PRIO_LOWEST,
 *  LV_THREAD_PRIO_LOW, LV_THREAD_PRIO_MID, LV_THREAD_PRIO_HIGH, LV_THREAD_PRIO_HIGHEST
 *  Make sure the priority value aligns with the OS-specific priority levels.
 *  On systems with limited priority levels (e.g., FreeRTOS), a higher value can improve
 *  rendering performance but might cause other tasks to starve. */
#define LV_DRAW_THREAD_PRIO LV_THREAD_PRIO_HIGH
#define LV_USE_DRAW_SW 1
#if LV_USE_DRAW_SW == 1
     * Selectively disable color format support in order to reduce code size.
     * NOTE: some features use certain color formats internally, e.g.
     * - gradients use RGB888
     * - bitmaps with transparency may use ARGB8888
    #define LV_DRAW_SW_SUPPORT_RGB565       1
    #define LV_DRAW_SW_SUPPORT_RGB565_SWAPPED       1
    #define LV_DRAW_SW_SUPPORT_RGB565A8     1
    #define LV_DRAW_SW_SUPPORT_RGB888       1
    #define LV_DRAW_SW_SUPPORT_XRGB8888     1
    #define LV_DRAW_SW_SUPPORT_ARGB8888     1
    #define LV_DRAW_SW_SUPPORT_ARGB8888_PREMULTIPLIED 1
    #define LV_DRAW_SW_SUPPORT_L8           1
    #define LV_DRAW_SW_SUPPORT_AL88         1
    #define LV_DRAW_SW_SUPPORT_A8           1
    #define LV_DRAW_SW_SUPPORT_I1           1
    /* The threshold of the luminance to consider a pixel as
     * active in indexed color format */
    #define LV_DRAW_SW_I1_LUM_THRESHOLD 127
    /** Set number of draw units.
     *  - > 1 requires operating system to be enabled in `LV_USE_OS`.
     *  - > 1 means multiple threads will render the screen in parallel. */
    #define LV_DRAW_SW_DRAW_UNIT_CNT    1
    /** Use Arm-2D to accelerate software (sw) rendering. */
    #define LV_USE_DRAW_ARM2D_SYNC      0
    /** Enable native helium assembly to be compiled. */
    #define LV_USE_NATIVE_HELIUM_ASM    0
     * - 0: Use a simple renderer capable of drawing only simple rectangles with gradient, images, text, and straight lines only.
     * - 1: Use a complex renderer capable of drawing rounded corners, shadow, skew lines, and arcs too. */
    #define LV_DRAW_SW_COMPLEX          1
    #if LV_DRAW_SW_COMPLEX == 1
        /** Allow buffering some shadow calculation.
         *  LV_DRAW_SW_SHADOW_CACHE_SIZE is the maximum shadow size to buffer, where shadow size is
         *  `shadow_width + radius`.  Caching has LV_DRAW_SW_SHADOW_CACHE_SIZE^2 RAM cost. */
        #define LV_DRAW_SW_SHADOW_CACHE_SIZE 0
        /** Set number of maximally-cached circle data.
         *  The circumference of 1/4 circle are saved for anti-aliasing.
         *  `radius * 4` bytes are used per circle (the most often used radiuses are saved).
         *  - 0: disables caching */
        #define LV_DRAW_SW_CIRCLE_CACHE_SIZE 4
    #define  LV_USE_DRAW_SW_ASM     LV_DRAW_SW_ASM_NONE
    #if LV_USE_DRAW_SW_ASM == LV_DRAW_SW_ASM_CUSTOM
        #define  LV_DRAW_SW_ASM_CUSTOM_INCLUDE ""
    /** Enable drawing complex gradients in software: linear at an angle, radial or conical */
    #define LV_USE_DRAW_SW_COMPLEX_GRADIENTS    1
/*Use TSi's aka (Think Silicon) NemaGFX */
#define LV_USE_NEMA_GFX 0
#if LV_USE_NEMA_GFX
    /** Select which NemaGFX HAL to use. Possible options:
     * - LV_NEMA_HAL_CUSTOM
     * - LV_NEMA_HAL_STM32 */
    #define LV_USE_NEMA_HAL LV_NEMA_HAL_CUSTOM
    #if LV_USE_NEMA_HAL == LV_NEMA_HAL_STM32
        #define LV_NEMA_STM32_HAL_INCLUDE <stm32u5xx_hal.h>
    /*Enable Vector Graphics Operations. Available only if NemaVG library is present*/
    #define LV_USE_NEMA_VG 0
    #if LV_USE_NEMA_VG
        /*Define application's resolution used for VG related buffer allocation */
        #define LV_NEMA_GFX_MAX_RESX 800
        #define LV_NEMA_GFX_MAX_RESY 600
  • MCU/MPU/Board: ESP32-S3-WROOM-1-N16-R2
  • LVGL version: V9.3.0
  • ESP-IDF version: V5.3.1
If you are creating the buffer dynamically, use
heap_caps_aligned_alloc(LV_DRAW_BUF_ALIGN, BUFFER_SIZE, FLAGS);
https://docs.espressif.com/projects/esp-idf/en/stable/esp32s3/api-reference/system/mem_alloc.html#_CPPv423heap_caps_aligned_alloc6size_t6size_t8uint32_t
